11-28-2005, 02:42 PM | #1 |
Tachometer recommendation
Guys (gals too I guess...); I need some recommendations on a tach for my 1984, C10, silverado, (modded) 305, auto. I want to mount a tasteful tach either on the dash top corner, steering wheel column, or maybe under dash about where the ashtray is......I need some recommendations on some good, reasonably priced, tachometers..........THANKS! AND, installation tips if you have any.........
"Fighting for our freedoms....." |
11-29-2005, 11:01 AM | #2 |
Re: Tachometer recommendation
Anybody got any thoughts on this??
11-29-2005, 11:29 AM | #3 |
i personally like a midsize autometer, white face, mounted on the steering column....but thats just me....they hook up real easy, almost foolproof
summit usually is the cheapest i've found to buy them from...i dont have time right now to find a link, but i'm thinking without a shift light, there only around $50-65
1987 350 TBI lowered 5/7 Last edited by bigarmzz; 11-29-2005 at 11:29 AM. |
11-29-2005, 11:34 AM | #4 |
Hey there bigarmzz...thanks for the input...BTW, how hard is this thing to hook up?
11-29-2005, 12:53 PM | #5 |
Magnificent bastard
I just put an AutoGauge tach in my Suburban. Got it from Summit, was only about 50 bucks, I think (model 2300). Pretty nice unit, easy to hook up. Just a switched +12V, a ground, a wire to the distributor tach terminal, and one for the backlight. I mounted mine on the steering column so when you put it in Drive, the tach is centered straight up on the column. Works great.
1977 Big Block Burb |
11-29-2005, 01:09 PM | #6 |
yeller
I mounted a tach on the column in my 77 Blazer. If you route the strap carefully, it (the tach) won't move at all when shifting gears and will always be in the same position. Here is a pic of it.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
11-29-2005, 01:14 PM | #7 |
Thanks so much folks!
11-29-2005, 03:43 PM | #8 |
Here's what I did... Cheapy Sun Pro Tach. ($29.00 at Autozone) and some hose clamps...
- Dave
2003 Silverado K1500 Z71 - Arrival Blue 1973 K5 Cheyenne Blazer 350/TH350/NP203 Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift. RETIRED: 1980 Scottsdale 4x4 Founding Member: "TILT WHEEL BELLY." Club |
12-02-2005, 01:57 AM | #9 |
It followed me home?
mine
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
12-02-2005, 02:15 AM | #10 |
I'm back with 2nd truck!
I installed the Autometer Pro-Comps and surfaced mounted them. Like here
But I used these gauges. I'll eventually get a new bezel and mount them like the 2nd picture.
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
12-02-2005, 10:11 AM | #11 |
*Proud Member*
Not at all what you probably had in mind, but i went OEM:
12-02-2005, 05:32 PM | #12 |
THX all...good stuff!
12-02-2005, 11:19 PM | #13 |
Parts and more parts
I have mounted a 3" Auto Meter tach on the post just above the dash pad. I used a flat stap of aluminum and drilled one hole in it for the screw that holds the plastic trim to the post to go through (I had to use a longer screw). I cut the end of the bracket at an angle (where it lines up with the windshield rubber gasket), this will hold the bracket at the angle you want it to sit at. On the other end I drilled two holes for the mounting bracket of the tach to bolt to. This strap is not very long and the tach face sets about even with the edge of the dash. OH BY THE WAY, there are no holes in the dash top and when you take it out, the post is clean also.
12-02-2005, 11:21 PM | #14 |
Got any pix....? THX!!
