Old 12-02-2005, 05:02 PM   #1
qksilver
SWB frame questions.......
Thought I was being slick, bought 2 SWB 4X4 trucks with wasted frames but other wise in good shape. Gathered 4 so far 2 wheel SWB frames, coil springs.
Whoops, was going to rob all the brackets etc off the 4X4 frames and drill and rerivet to the 2 wheel frames.
Question is, it looks like the coil spring frames are kicked out for the coils in the rear. Can I still mount all the brackets etc on the coil and make it a SWB 4X4 frame.
One of the 4X4 is a 67 swb and I want to restore that one, I have 2 67(no dimple) SWB coil frames.
Where the heck would I find a great 67 leaf rear, 2 or 4 wheel drve frame?
I hope this makes sense.
Thanks,
Steve
qksilver is offline   Reply With Quote
Old 12-02-2005, 05:35 PM   #2
72MARIO
72MARIO's Avatar
Re: SWB frame questions.......
Yes the frame are the same. The shape does not change just crossmember placement.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 12-02-2005, 05:40 PM   #3
72MARIO
72MARIO's Avatar
Summit sells the axel perches just cut off the ones from a 73 up axel and your set. Make sure it's a 6 bolts axel.
2005 TAHOE DD
Old 12-02-2005, 09:45 PM   #4
qksilver
cool, that saved me a bunch of money and time. The 2 wheel drive frames here are really clean but the 4X4's.............
Thanks,
Steve
Old 12-03-2005, 08:21 AM   #5
ZOOMY
The 2wd and 4wd frames are different, just like you said. You can convert them though. I just parted out a 4x4 with a 2x4 frame.
ZOOMY is offline   Reply With Quote
