Old 12-03-2005, 02:37 PM   #1
70short
Talking Stall converter
OK I purchased A hughs 10" 3000 stall converter from A guy I know for $150.00. I put It in yesterday and took it for A spin. I installed A TH400 in place of my old granny 4-speed. 308 gears and no kickdown switch yet.
cons:
1) It feels like A slipping clutch when starting out: However it isnt like it waits until the truck gets to 3000 rpm before it starts to move.
2) It softened my shift kit that I installed. I will have to go back into the trans and drill bigger holes to get my harder shift back. (transgo shift kit).
3) I seem to be always cruising around 2000 RPM. Gas milage will suffer.
pros:
1) OH my god Hold on to your pants because this thing really wakes up when you mash the gas. FUN FACTOR is here for sure.
2) When I put the truck into drive it doesnt slam into gear.
3)When I mash the gas from A dead stand still it melts my 295 50 15. I wish I had A limited slip.
4) When stopped at an intersection I dont have to mash hard on the brakes to hold the truck from inching foward. 4 wheel drums manual version.
Bottom line it is very fun!!!
OH one more thing I am glad I installed A 1 piece driveline
Gary
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 12-03-2005, 02:58 PM   #2
MrC1
Dork For Days
MrC1's Avatar
Re: Stall converter
Sounds cool, but make sure you put a nice big trans cooler on that thing. It's not a good idea to have your cruise speed less than your stall speed due to the heat you create in the converter....plus the inefficiency (bad mileage).
Does sound ike it'd be more fun to drive though!
1972 C20, 402/700R4 - My first classic truck, bought in September 2005. 85% transformed from "Farm" to "Cool" status!
1970 Dodge Challenger 440, 4sp (my other toy) 12.67 @ 117 MPH, with a pathetic 2.022 60'
2007 Dodge Charger SRT-8
2008 Cadillac CTS
All-American garage, baby!
MrC1 is offline   Reply With Quote
Old 12-03-2005, 03:06 PM   #3
70short
Re: Stall converter
I am running the 28,000 GVW transcooler. That should be enough. I dont think they make one bigger?
Edel 600 cfm carb
HEI
shorty Headers
4/2 Drop
"CHEVY RULES"
Old 12-03-2005, 04:33 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Stall converter
that is a WAY bad thing to cruise under the rating. You should consider a gear swap.
Old 12-03-2005, 04:56 PM   #5
phantom dually
Project92 SWB stepside
phantom dually's Avatar
Re: Stall converter
Have fun!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 12-03-2005, 05:12 PM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Stall converter
I beleive you need the gears.With the convertor that loose you may will overheat the tranny constantly.You may already be able to smell the difference in the tranny fluid.A cooler will cool the fluid but it may be getting hot enough in the tranny(before it gets to the cooler) to cause some damage.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-03-2005, 06:07 PM   #7
71Dragtruck
71Dragtruck's Avatar
Re: Stall converter
B&M makes a bigger one 29,500 11" x 11". TCI makes one that is 15" x 12". Plus you can get them with fans.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 12-03-2005, 06:30 PM   #8
bigjimzlll
bigjimzlll's Avatar
Re: Stall converter
just run some synthetic tranny fluid if heat is a consern
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 12-03-2005, 06:48 PM   #9
Longhorn Man
Re: Stall converter
and a spare tranny.
If you were to call ANY of the converter tech lines, they'll tell you the same.
