KEEP ON TRUCKIN.
Wiring For New Headlights..
Put In The New Euro Crystal Clear Headlights This Weekend ,bought The Harness That Goes With It ...need Help Finding Out What To Do About The 3 Prong That Comes Out Of The Fuses.......i Know It Needs To Go To The Fuse Box Or Somewhere ..can Figure Out Most Stuff ........not This .......if Anyone Out There Has Done This Can You Guide Me Threw It ...everything Ispluged In The Headlights & Power To Battery Direct Wires Also..thanks In Advance..
1975 C-10 STEPSIDE (ALMOST DONE AGAIN)90 percent done wheres that other 10 haha .1994 GMC Z71 . |
Until Seventy Times Seven
Re: Wiring For New Headlights..
75silverstep-
I'm not quite following what saying. Are you looking for the wiring configuration from the fusebox to the headlights or ??? I haven't done this conversion, but I have the wiring schematics for the later 80s trucks and can check it for you, if you like.
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
Parts and more parts
I am at a loss also. My guess would be that the harness is setup to go to the battery directly for the power to the headlights. The other wires and a relay would included a ground wire (black) and then a connection that would plug into the original headlight harness, so that when you turn on the headlights inside the truck the power from that circuit would actuate the relay and turn on the new lights. The harness is probably wired so that it is simple to connect to the plugs that are already in the truck. My guess is that the 3 prong connector is for a standard headlight plug that is up by the radiator support.
LED King
I have all Euro composite lights and the relay harrness - So you plugged the 4 plugs onto the lights, power and ground right? The last connection should be 5th connector which will plug into one of the old light plugs currently on the truck - this supplies the signal voltage to turn on the relays to turn on the headlights.
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
#5 | |
KEEP ON TRUCKIN.
