Old 12-07-2005, 05:06 PM   #1
Rick.Coleman
Question LT1/LS1 Engine Management
I have an LT1 and 4L60E transmission from a 96 Trans-am WS6 for installation in my 52 Chevy truck. The truck will have all power options/AC/cruise control/etc. The engine/trans will remain stock but I want to clean it up by removing any/all the smog stuff I can. I have the original computer and harness from the TA, but the harness does have some damage from an accident. I would like to get some ideas/advise on how others have dealt with installing the LT1/LS1 into non pollution required vehicles. What pollution control items can I remove and how did you handle the computer/harness as far as re-programmed or replacing the entire engine management system
Rick.Coleman is offline   Reply With Quote
Old 12-07-2005, 11:17 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: LT1/LS1 Engine Management
I've got the same set up in my 48 (http://67-72chevytrucks.com/vboard/s...d.php?t=179199)
An aftermarket harness is the way to go, it will save you time, money and headaches. Most are very simple to hook up. There are many companies out there:
Street and Performance
Painless
Howell Engineering (this is the one I used, but all are good companies)
Ron Francis.
Rob
Hart_Rod is offline   Reply With Quote
Old 12-11-2005, 08:43 AM   #3
Seon
Seon's Avatar
I have a 5.3 Vortec and 4l60e tranny in my '56 Burb. I just mailed my harness and PCM to http://www.wait4meperformance.com/ for him to modify the harness as a stand alone and reflash the PCM for $340 includes return shipping. I learned about Jess Bubb owner from another forum that had nothing but high praises about his work. Good luck.
Seon is offline   Reply With Quote
Old 12-12-2005, 12:20 PM   #4
midwestcar
midwestcar's Avatar
do a painless kit...had no problem installing it. it works great.
midwestcar is offline   Reply With Quote
Old 12-12-2005, 03:12 PM   #5
Rick.Coleman
Thanks. This is all good information. I hope it keeps going as I like being informed before I make my decision.
I would still like to know what I can get rid of in the smog department. I want to put headers on the truck and based on what I've read I should keep the o2 sensors on the exhaust but can get rid of the rear o2 sensors since I will not run catalytic converts. I am also thinking I can get rid of the air pump, and egr. Like to have your opinions.
Old 12-14-2005, 04:31 PM   #6
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Might also look into megasquirt. Built it yourself and install.
http://www.megasquirt.info/
ElGracho is using one on his:
http://www.gmcspecialeditions.com/
And I am sure you have seen this 10 second pickup he is also using megasquirt:
http://www.neufamily.org/truck.html
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-15-2005, 10:33 PM   #7
3100 special
Street Rod Dreamin'
3100 special's Avatar
Location: Work:Batam, Indonesia/ Home:League City, Texas
Welcome to the board!
1954 Chevy 3100 Panel Truck
2004 GMC Yukon
2007 GMC Sierra 4X4
"I am for doing good to the poor, but I differ in opinion of the means. I think the best way of doing good to the poor, is not making them easy in poverty, but leading or driving them out of it."
Benjamin Franklin, On the Price of Corn and Management of the Poor, November 1776
3100 special is offline   Reply With Quote
Old 12-18-2005, 08:16 PM   #8
FirstGen
Just Don't Stop!
FirstGen's Avatar
Just so you know, MegaSquirt will not allow you to control timing on a LS1 motor with coil on cyclinder design. Nor will it allow sequencial fuel injection only batch or bank fire systems.
It is great for controlling fuel in a boosted LS1 design when you have gone past the air volume max on the Mass Air Flow meter but it won't allow you to do a lot of the simple stuff that LS1Edit or HPTuners will...
Just FYI,
Taylor
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
