Old 12-09-2005, 10:48 AM   #1
mhicks
mhicks's Avatar
Won't warm up!!
I have installed 2 new thermostats in my '73 350 and it will not warm up. The temp stays at the first mark on my temp gauge and the heater blows cold air or just a little warm. Any clues?
mhicks is offline   Reply With Quote
Old 12-09-2005, 11:17 AM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: Won't warm up!!
Well, this is just guessing since I know know the history, but it is possible that the sending unit to the guage isn't working and the Heater core is stopped up at the same time? If you still have the t-stat you can check it by putting it in water brought up to the specified temp.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-09-2005, 11:42 AM   #3
Russell
Professional Grade
Russell's Avatar
Re: Won't warm up!!
My guess would be that your thermostat is stuck open. That happens to me all the time, at least twice a year, but thats due to the fact that I always buy the cheap Napa ones, lol
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 12-09-2005, 11:46 AM   #4
mhicks
mhicks's Avatar
Re: Won't warm up!!
Well, I have had them stick open before too and that is why I gave 10.99 for mine. I used to buy the cheaper ones and they stick open too so I started buying the more expensive ones. Maybe I need to take this one back and get the mid priced one because there is nothing else it could be. Right?
Old 12-09-2005, 11:59 AM   #5
86 GMG
Re: Won't warm up!!
what type motor is is b/c if the heater hose is located at the water pump instead of the radiator or visa versa (sp?) sbc is what im talking about one of the hoses goes to the intake the other can go to the pump or rad. you might swop this hose around and see if that helps just a thought. and will someone else chime in on this topic that knows more than me on a logicall explaination on the diffrences on why it make it work diffrence on some motors
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
Old 12-09-2005, 12:05 PM   #6
TrainD5115
North Coast, baby!
TrainD5115's Avatar
Re: Won't warm up!!
I just had this problem yesterday after installing a new t-stat. On my end it appears that I had alot of water in my system which translated into ice blocking the lines and heater core. After a lengthy warm up and a complete flush and refill with quality anti-freeze, I have good heat again.
Brad
79 Scottsdale C20
350/350
3.73's
Still running full CA smog gear!
TrainD5115 is offline   Reply With Quote
Old 12-09-2005, 01:52 PM   #7
Captkaos
Captkaos's Avatar
Re: Won't warm up!!
You can check the t-stat like I listed above before returning it and see if it is sticking.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 12-09-2005, 03:34 PM   #8
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Re: Won't warm up!!
Carboard in front of the radiator? Might help if everything else is okay and working.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 12-09-2005, 04:08 PM   #9
bodydropped
Re: Won't warm up!!
my 78 only goes to the first mark to but it blows really really hot air i sometimes have to turn the vent on
bodydropped is offline   Reply With Quote
Old 12-09-2005, 10:26 PM   #10
marvxyz1
marvxyz1's Avatar
Re: Won't warm up!!
Check to see if you've got thermostat in backwards. The spring goes toward the motor.
marvxyz1 is offline   Reply With Quote
Old 12-09-2005, 10:29 PM   #11
marvxyz1
marvxyz1's Avatar
Re: Won't warm up!!
Check to see if you might have the thermostat in backwards.. The spring goes toward the motor.
Old 12-10-2005, 12:48 AM   #12
SSC's76
No No
SSC's76's Avatar
Re: Won't warm up!!
What temp t-stat did you get? Like mentioned a plugged heater core or improper mix of antifreeze will contribute to heat loss. I use to have a real good heater until I needed a new heater core. Some of these aftermarket junk HC's dont work quite as well as OEM.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 12-10-2005, 08:29 AM   #13
mhicks
mhicks's Avatar
Re: Won't warm up!!
I have the spring down, towards the motor. Still has the original heater core. I put a new crate motor in back in the summer and haven't used the heater much until now. I have noticed that the temp control for heater will not slide all of the way to heat. I'm thinking that the gauge is supposed to stay at the first mark when engine is warmed up but I was thining it should be half-way. I think I will dig in to the dash and find out why the temp control doesn't slide all the way to heat. Maybe it has something to do with that. It likes about 3/4 of an inch to going all the way to the right.
Thanks Guys,
Mike
Old 12-10-2005, 09:10 AM   #14
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Re: Won't warm up!!
Sounds like the cable is binding on something. The temp guage in my truck goes up about a 1/4 of the way and stays there. I have great heat. I'm not asking this to make you sound bad but do you have the heater hoses on right. If thats not the problem then it sounds like the heater core is stopped up.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
http://67-72chevytrucks.com/vboard/payments.php
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 12-10-2005, 01:40 PM   #15
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Re: Won't warm up!!
Also how do you have your heater lines ran? When you installed the motor you have have swapped some lines to or from the heater.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 12-10-2005, 01:44 PM   #16
mhicks
mhicks's Avatar
Re: Won't warm up!!
No, I think I have them right. The big hose comes off of the waterpump and goes to the top input at the firewall and the small hose comes off of the intake and goes to the bottom input on the firewall. I am beginning to think the heater door isn't closing all the way because of a problem with the cable. Will probably check that tonight.
Old 12-10-2005, 01:48 PM   #17
79BIG10
79BIG10's Avatar
Re: Won't warm up!!
I think you have the problem there. Mine come off the intake to the heater core and the other from the heater core goes to the radiator on the passenger side by the cap.
Old 12-10-2005, 02:18 PM   #18
Bishops Trucks
KEEP ON TRUCKIN'
Re: Won't warm up!!
Mine is 3/4 hose on the bottom going to the intake and the 5/8 hose on the top going to the waterpump. It gets hot in my truck to where I have to open the back window. What year truck are we talking about anyway?
JIM
Old 12-11-2005, 12:25 AM   #19
79BIG10
79BIG10's Avatar
Re: Won't warm up!!
It's a 73. The one thing that's different on BB and SB is the port on the water pump. SB have it plugged off and BB have the port open to the intake right above it.
Old 12-13-2005, 07:47 PM   #20
C&C Chevy
C&C Chevy's Avatar
Re: Won't warm up!!
hicks, did you ever find out what happened? Mine is doing the same thing. Just wonderin'.
Robert
Current:
1986 SWB Silverado 4.3 / TH400
Past:
1985 SWB Silverado 305 / TH350 - sold 1995
1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007
C&C Chevy is offline   Reply With Quote
Old 12-14-2005, 08:23 AM   #21
mhicks
mhicks's Avatar
Re: Won't warm up!!
No, I haven't had a chance to check it out anymore. It does seem to be blowing a little air out the defrost while in the heater position. I think I'm going to have to tear into the dash again.
Old 12-14-2005, 09:43 AM   #22
86 GMG
Re: Won't warm up!!
m hicks before you start changing stuff swap your hose from your waterpump to the port on the radiator i almost garantee its the problem if you will look at my first post i mentioned this.
Old 12-14-2005, 10:51 AM   #23
mhicks
mhicks's Avatar
Re: Won't warm up!!
If I do that then I would have to change the size of nipples coming out of my intake and waterpump. I know when I swap the motor that I put the correct nipples in the correct spots. I got it from my dad a couple of years ago and he bought it new and I don't think that would have been messed with.
Old 12-14-2005, 12:21 PM   #24
86 GMG
Re: Won't warm up!!
i,m not saying anything about you not have it done right just the fact that i have been in your shoes and this was my problem. as far as the items being in the right place either set-up is "correct" except the fact that some motors ? require one way and others the other way ?????? can't explain it but would hate to see you drive a cold trip where ever you go just because a couple hoses needed to be moved along with the nipples best luck keep us updated and tellus what was wrong when you get it fixed.
