Old 12-11-2005, 02:47 AM   #1
BowTieMan
BowTieMan's Avatar
Alignment after drop springs
If I go with 3 in. drop springs and stock spindles can I get an alignment and everything still be ok? My friend had an s-10 with just drop springs and a shop said he needed spidles in order for them to align it.
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
BowTieMan is offline   Reply With Quote
Old 12-11-2005, 07:30 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Alignment after drop springs
Yes, you can still align a full size truck with 3 inch drop springs.
There is a fundamental difference between S-10's and full size trucks. On a full size, you add shims to increase the camber. You can add shims till you run out of stud room. On an S-10, you remove shims to increase camber. Once you remove the shims that are there, you can't adjust it any more. That's why S-10's can't usually be aligned with a 3 inch spring.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
