need exhaust help with engine swap
ok. going from straight six in my 83 to 350 engine. i have long tube headers that came with engine but....the exhuast off the headers will run into the crossmember for trans. what do you guys do to run headers? do i need a new crossmember or do i need different headers? i can go to stock exhaust manifolds if i have to but i prefer to run headers. thanks jim
Professional Grade
Re: need exhaust help with engine swap
Jim, what you need is a transmission crossmember from an early SM465 truck (like 73-78 or so). They have two large humps in them to allow for dual exhaust to travel underneith them on either side of the transmission. Your 83 will have a crossmember that probally has a single downwards dip in it for the factory single exhaust to go overtop of it. Depending on which transmission you are running, you'll likely need to drill a new hole in the crossmember (most of the SM465s I've seen of that era have two bolts holding the tranny down at the back, while many of the newer transmissions only have one in the center, and you'll definitely need to drill new holes in at least the lower plate of the frame.
The crossmember is a 3 peice unit, the big member that goes all the way across, and sits on top of the bottom plate of the frame, with two little supports that go to the top of the frame. Those upper plates are not essential to the strength of anything, so you can choose to omit them if you wish. BTW -- You have a PM
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) Last edited by Russell; 12-11-2005 at 04:13 PM. |
I just installed headers on my truck and I started with set of car headers and realized that they weren't going to work because the passenger side one dumped right into that crossmember. I ended up buying some Dynomax truck headers which dump a bit lower. The exhaust shop still had to do a bit of bending to get it to work, but the truck headers eliminated the need for any extreme angles that would restrict flow.
The only issue with going with the full length truck headers is ground clearance. They had to put the passenger side pipe under that crossmember, so that reduces the clearance by 2.5 inches. If you are planning on slamming the truck some time in the future, you should probably get some shorty headers and get the pipe bent tight to the cab. If you do, be sure to get rear (not center) dump shorty's.
Evan B. |
Regular guy
I ended up building my own crossmember.
I have a ton of room now.
'Frank' 77 Silverado 18 & 20 American CL205s Edelbrock MPFI, 700r4, Baer Brakes 9" F@rd rear, Vintage air, Bags etc etc.. |
#5 | |
Happy to be here
![]() Join Date: Mar 2000
wow ! those members look sweet ! doesnt look too hard to build one either.
#7 | |
my exhaust (off daves old truck) was just routed around the stock member, one pipe went above, other below....
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
