Old 12-15-2005, 01:06 AM   #1
jimfulco
Door won't unlatch
I have a '73 with a '75 passenger door on it, and I can't get the thing to unlatch so I can remove the door. I've hosed it down with WD-40 from all possible directions, tapped & bumped with my fist for vibration, pried (not too hard) with a big screwdriver, and tried it from inside and out. It's only half-latched, in other words not completely shut, but it refuses to budge. It's not locked. Anybody got an idea how I can get this thing open without destroying it?
jimfulco is offline   Reply With Quote
Old 12-15-2005, 09:29 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Door won't unlatch
It sounds like your going to have to remove the door panel and go inside. That may take a little work trying to get it off with the door closed, but I don't see too many other options....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-16-2005, 02:40 AM   #3
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Maybe moving the locking up and down will help. (Maybe the locking mechanism is stuck. You could also try to completely shut the down and try again. (But again, it may end up completely latched.) Like N2 said, taking off the door panel may be a bear with the door close.
Good luck.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 12-16-2005, 11:47 AM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
With the door closed it won't be easy, but with it being a '75 door, the panel doesn't cover the whole area. You will probably need a stubby screwdriver, but it can be removed.
Are you thinking the door handle isn't working, or the latch?
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-16-2005, 11:36 PM   #5
Bowed
I can see you have tried just about everything but did you try pushing upward on the door while trying to open it ?
Bowed is offline   Reply With Quote
Old 12-16-2005, 11:49 PM   #6
olblue81
olblue81's Avatar
To open my driver's door from the outside, I have to push the button with my thumb and 'side step' it off if you know what I mean. The button pops out and the door will open. If I just push the button in normally, the button stays in and the door stays shut. Hope this works for you.
Stu-
1981 GMC Sierra Classic LWB
355- original 2 bolt block, 10.2:1, vortec heads, Comp XE268 cam, built by self in 1992
700R4-2000 stall with lockup, shift kit, Corvette servo
3.07 open diff- I need a 3.73 posi!
2nd owner since 1986 - 388,000 km and counting. 100k by the first owner and the rest by me.
olblue81 is offline   Reply With Quote
