Old 12-17-2005, 02:33 PM   #1
Austin C10
1972 C10 Cheyenne LWB
Starting in colder weather
I'm pretty new to carburated engines. Its in the 40s here in Austin, nothing unreasonable.
I usually start my recently purchased 1972 C10 by pressing the gas in all the way, letting it out slowly, then cranking it. The first time I crank, it the engine coughs like its gonna keep going, so I stop cranking, but it dies out immediately. Should I give it gas right away?
The second time I crank it, the battery just wears down. Should I give it gas while cranking it the second time?
Maybe my battery's just not up to the task. I'm gonna test it this afternoon.
Austin C10 is offline   Reply With Quote
Old 12-17-2005, 02:54 PM   #2
Mongo
YES_____NO
Mongo's Avatar
Re: Starting in colder weather
I give a two or three quick pumps ofthe gas then lightly press down as I turn the key. It fires right up. I offten have ot feather the throtle a little to keep her gong. after about 2min she runs on her own.
People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown
Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984
Help support the board
Mongo is offline   Reply With Quote
Old 12-17-2005, 03:11 PM   #3
classicchev
classicchev's Avatar
Its always cold up here, sounds like you need to adjust your choke. If properly adjusted, 1 pump and it should fire and run on its own. depending on the carb you have, depends on how much trouble you will have adjusting.
Edelbrock and Quads are the easiest, Holleys are a little more of a challange for the cold weather up here in the COLD north, but once they are adjusted, they work great.
67- 72 Parts collecter
classicchev is offline   Reply With Quote
Old 12-17-2005, 03:23 PM   #4
Austin C10
Good tips all the way around. I plan on looking into the choke also. When you say one pump and it runs on its own, do you mean that after I pump it once, take my foot off crank and it ought to fire up if the choke is properly adjusted?
Old 12-17-2005, 03:33 PM   #5
classicchev
There are many variables to a good start. Battery, Plugs, wires, quality of spark, last time run, quality of carb ETC ETC. Usually with the Edelbrock, MSD box, 1 pump to set the choke and give some fuel, and she starts. This depends one the temperature, If its really cold -30 C (F????) May take a little more cranking. I doubt it gets that cold in Texas.
Should be a simple adjustment, If its a electric choke, loosen the screws on the choke and give it a turn clockwise and slowley open up the trhrottle and see if the flaps close, if they dont, turn a little more until they do. Remember to turn the key on, choke needs power. .Oh yah, do this with a cold non running engine.
Old 12-17-2005, 04:05 PM   #6
shelby987
shelby987's Avatar
I had a similar problem with my truck, have yet to tear into the carb, but my temp. solution is to pull out the choke, tap the gas, let it fire (and then die), after that, I found that very quick, very slight taps on the gas with the key turned will get the engine to start, I continue tapping until I can get the engine into the higher rpms (1,500~2,000), hold it there, and let it warm up for a couple of mins....yeah, its not perfect, but its a heck of a lot better than running back and forth with a can of starting fluid in 10 degree weather!
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 12-17-2005, 04:06 PM   #7
shelby987
shelby987's Avatar
oh wait, just re-read that, you are in texas.....tell your truck 40 degrees isn't cold, and if it doesn't start you will ship it up here to the rust belt with its other bad brothers and sisters! should fire up without a problem....if it knows whats good for it!
Old 12-17-2005, 05:20 PM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I press & release the throttle one time only, just enough to set the choke (you can hear it click). then it fires right up -- good for temps in the teens. Sometimes it'll start, then stumble & die. If it does, I crank it again without touching the throttle at all -- it then keeps running at fast idle.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 12-17-2005, 06:46 PM   #9
classicchev
you guys dont know what cold is!! Then you put a wind with it.. BBRRRRRR
Old 12-17-2005, 06:58 PM   #10
71chevylongbed
Got Horsepower?
71chevylongbed's Avatar
sounds like choke. its been getting under 10 degrees F here and when i go to start my truck in the morning i only have to push the pedal to the floor once to set the choke and it fires right off and stays running on its own
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit"
SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers
71chevylongbed is offline   Reply With Quote
Old 12-17-2005, 10:18 PM   #11
71-longbed
Its Magically Delicious
71-longbed's Avatar
i agree with stocker ...thats what i do ...
sometimes i need to massage the pedal alittle after its started ... not always though
Its was down to 20 last night
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
