Old 12-17-2005, 06:49 PM   #1
webbes
need id on frontend
I found the number on the front axle but can not find out what it is. The build number is 60333-3. I think it is a Dana 44 ????
webbes is offline   Reply With Quote
Old 12-17-2005, 07:02 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Re: need id on frontend
easiest way to tell is, a raised "44" in the lower right webbing on the center section as you look at the front of the vehicle, a 10 bolt has ears on the lower left and right of the center section, finally a dana 60 mounts with 3 u-bolts and 2 studs, the other two use 4 u-bolts.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 12-18-2005, 08:01 AM   #3
Blazer1970
Blazer1970's Avatar
60333 is not a valid Dana BOM number. It should be six digits. Look a little closer.
Blazer1970 is offline   Reply With Quote
Old 12-18-2005, 09:48 AM   #4
b454rat
Did a quick search on the Dana expert for 603, and it comes up with a Jeep axle. The expert only goes back till 77 or so, so if it's an older axle it won't come up.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 12-18-2005, 07:29 PM   #5
webbes
Sorry I left a number. It should be 603333-3. It is suppuse to be a 1972 frame and suspension.
Old 12-18-2005, 11:43 PM   #6
Americanrider
this is where to look. The pic is from a Dana 60 but the raised numbers is the same for the Dana 44 too.
Americanrider is offline   Reply With Quote
Old 12-19-2005, 07:52 AM   #7
Blazer1970
Blazer1970's Avatar
I don't see 603333 anywhere in the '67 - '78 Dana catalog.
