12-19-2005, 01:08 PM | #1 |
disassembling wood bed
i know this has been discussed before...
what is the easiest way to remove the wood floor? remove bed and set on its end? grind out bolts? those things look rusty! |
12-19-2005, 01:31 PM | #2 |
I'm watching you!
Re: disassembling wood bed
Chainsaw
Sorry I couldn't resist, I am of no help. Mike
2012 Chevrolet Silverado 1500 Z71 4WD 1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP) 1992 Chevrolet S10 - LS swap project 1968 Chevrolet C-10 longbed fleetside - sold |
12-19-2005, 10:24 PM | #3 |
The easiest thing to do is to weld the carrige bolts to the bed strips and remove the nuts or snap them off. It sounds stoopid but it's the easiest way.
71 GMC 1500 LWB |
12-20-2005, 01:09 AM | #4 |
thanks for the suggestion spoof.
12-20-2005, 10:21 AM | #5 |
Impact Gun and tighten them untill they break. Loosening them will just be a pain in the neck.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
12-21-2005, 12:10 AM | #6 |
The problem I had with trying to snap them off is that the carrige bolt will just strip the bed strip seats and simply spin.
I used a grinder, torch...you name it. When you do weld up the bolt head to the strips it will have to be more than a tack.
71 GMC 1500 LWB |
12-21-2005, 06:48 AM | #7 |
When I did my bed the wood was so bad I could break it out by hand and then I took a bolt cutter to the bolts. Not sure how bad your bed is but you could cut down the middle of the boards and get the wood out, That would leave you a few more options.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne |
12-21-2005, 10:22 AM | #8 |
Grrrrrrrrrrrrrinder!
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
