Old 04-22-2002, 10:00 AM   #1
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Post 1 more inch
I did the flip kit on my 72 and I need to get the rear end up just one more inch. What can I do? Are 4X4 shackles shorter than 2wd? and if so will they fit? After the flip kit the rear sits exactly 1" lower than the front and I hate the uphill look. Are there any add-a-leafs that will work.
72 Chevy C/10
87 Chevy Silverado 4X4
www.geocities.com/chevylwb/chevylwb.html
Aberdeen South Dakota
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
Old 04-22-2002, 10:13 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
Lifting blocks are inexpensive, and alot of parts stores carry them on the helf. Esp just a one or 2 inch block...probably no more than 30 bucks.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 04-22-2002, 10:41 AM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Post
Hockey puck. (just kidding!)
'69 K-5 Blazer - 350/TH350, 6" lift, 35" tires
Bothell, WA
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 04-22-2002, 10:45 AM   #4
69 longhorn
Post
Ummm,after a flip kit,a block will lower you more. On my longhorn,I did a flip on the rear axle,& relocated the brackets(moved down on the frame),approx 1 1/4" to get the height where I wanted. On the rear brackets I added a pc of 1/4" 3x3 angle to the bottom of the frame(bolted to the inside of the bracket to eliminate flex). You want to make sure & use grade 8 hardware,& pinchlock nuts.Good luck.....69 longhorn
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 04-22-2002, 11:21 AM   #5
Yukon Jack
Yukon Jack's Avatar
Post
www.offroaddesign.com has a zero rate block that give you 1" of lift and it is center bolted to the spring pack for added strength.
1969 C20 4x4 with roughly 6" lift and 35's
residing near Rose Hill, Kansas
Yukon Jack's Web Pages
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-22-2002, 03:33 PM   #6
Mike C
Mike C's Avatar
Post
But when you flip a two wheel drive, the axle is on top of the springs and the block lowers it even further. I would either try and find a set of springs that hard more arch than the ones you have, run a taller tire in the rear, or drop the front 1 more inch.
70 GMC 3/4 ton Sierra Grande 402/TH400
72 Jimmy 4WD 4spd 4" & 35's
64 Corvette Coupe
68 Camaro 'vert TPI & TH700
69 Z/28 355 12.6's @110
72 Datsun 240Z-ol' reliable
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
02 GMC 2500HD 4x4 Duramax
Old 04-22-2002, 03:49 PM   #7
69 longhorn
Post
Or relocate the brackets,if the budget goes like mine does at times........69
Old 04-22-2002, 04:03 PM   #8
imaindianoutlaw
GMC SHORT FLEET F/S
imaindianoutlaw's Avatar
Red face
my wife asked for the same thing! lol
Charles W. Hein
S. Williamsport PA
imaindianoutlaw@yahoo.com
REFRIGERATION TECH
1971 Rolling chassis
FOR SALE
1963 Pontiac Tempest
1965 Pontiac GTO
1956 Pontiac 2 dr
CHARLES WADE HEIN
HVACR FOREMAN.
LEWISBURG U.S.P.
imaindianoutlaw is offline   Reply With Quote
Old 04-22-2002, 04:09 PM   #9
69 longhorn
Post
What,1 more inch? hehe,mine did too.....I told her sorry,I never use it all!!!!!!!69
Old 04-22-2002, 05:38 PM   #10
bigblok
Post
The shackles from a van would work, and are shorter.
72 C10 475HP 402BBC
Yes, it's fun, but gas ain't cheap!
bigblok is offline   Reply With Quote
Old 04-22-2002, 06:46 PM   #11
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Post
What year van? 73-87 would have wider leafs, so they wouldn't fit into the shackle right? Hey Longhorn, do you need to lower both the front and rear mounts? I've been thinking about that. Also I might get air bags for it just for helpers right now. What kind of brackets would I need to make? Where do I mount them?
72 Chevy C/10
Old 04-22-2002, 06:49 PM   #12
Longhorn Man
Post
oops, you are right other longhorn...I was thinkin he flipped it to raise.
Old 04-22-2002, 06:57 PM   #13
69 longhorn
Post
Yes,I lowered both front & rear brackets. The fronts didnt need any bracing,but the rears I used a pc of 1/4" angle iron,(2 1/2 or 3",whatever fits the frame width). 3 bolts on the bottom of the frame,& 2 bolts to the hanger. I only moved them down 1 1/4".....now the longhorn frame is a little different,so you need to look see how the drop will affect the front hanger on yours. I upped the hole size to 7/16,& used grade 8 bolts ,& pinchlock nuts(lockwashers arent worth a sh*t on suspension stuff).I have run 10,000 mi since,& havent had any trouble. Good luck.....69 longhorn.
Old 04-22-2002, 07:01 PM   #14
69 longhorn
Post
Longhornmail,you got me on "just pop the clutch" this morning! Hehe,I didnt read it all,though I was talkin about an auto trans....oops.......69
