Old 12-21-2005, 08:11 PM   #1
dave3156
Which rearend will work?
Since the rearend has gone out (gears and case damaged) on my truck I will need to replace it. I have a five lug rearend (not original?) in my 70 Stepside which I plan to replace with a used rearend with 3:73 gears. I want to stay five lug so I can use the same wheels. I also plan on finding a complete rearend from wheel to wheel. What year vehicles have rearends that can bolt onto my truck? For instance would the rearend from a 78 Chevy truck work? Will a car rearend bolt up? It would really help to know what will work. I know many of you have already been through this. Please help so I can get my truck back on the road. Thanks
dave3156 is offline   Reply With Quote
Old 12-21-2005, 08:27 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: Which rearend will work?
Is your truck leaf or coil in the rear?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-21-2005, 11:07 PM   #3
dave3156
It is a coil spring suspension.
Old 12-21-2005, 11:42 PM   #4
jsbgump
Gone Fishing
jsbgump's Avatar
coil spring 5 lugs are only 71-72 chevy /gmc trucks
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
