Old 12-25-2005, 07:57 PM   #1
67-72williso
Junk/Daily Driver Club
67-72williso's Avatar
Smile 4X4 Frame Progress
Well I got the 73-up engine & swaybar crossmembers in the 72 SWB frame today. I mounted the engine crossmember in the C series BBC position. Since I`m using a divorced 205 anyway it won`t matter.
Daily Driver: 1970 C-20 400 sbc,sm-465,Dana 61 one ton SRW rear, 3.07 gears, locker.
There are three kinds of people: those who make things happen, those who watch things happen, and those who have no idea what happened!
67-72williso is offline   Reply With Quote
Old 02-11-2006, 06:13 PM   #2
4x4Poet
Interesting. I also plan on using a 73up X-member in a K20 burb frame for facilitating a BBC swap.
For what use is the X-member behind the 73up engine X-member? I don't think I've seen such on a 67-72 4x4 frame. Just the front & engine & tranny X-members (plus X-members further back but not engine/driveline related).
Someone is showing pics of how to install a BBC in a 67-72 4x4 and no one replies? What's up with that? This site is getting lame. Hopefully our usually sharp board members just missed the fine print in your sig.
You're going with a Clark 5-speed and divorced NP205? Interesting choices. I got a tip. I have a '71 IHC Travelall with a divorced, pass-drop NP205 stock. The inner frame measurements between my '71 K20 burb and the IHC are the same. I measured their inside frame to frame distances with a tape ruler.
I'm confident that one could use a '70s IHC Travelall divorced NP205 to include the cradle w/frame L-brackets mount by simply drilling 2 holes in each frame rail (4 total). The frame cradle is overhead, so you might have sheetmetal clearance issues under the cab. Also no skidplate. I think the IHC NP205 has 32-spline I/O shafts, but I'm not sure because I've never looked. It has 1310 yokes, but 1350 or 1410 yokes would likely fit all around if it has 32-spline shafts.
Keep us posted on your BBC into a 4x4 progress. Keep me posted, at least.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 02-11-2006, 09:00 PM   #3
67-72williso
Wink Re: 4X4 Frame Progress
That crossmember your talking about is the 2 WD bell housing crossmember. This was a 2 WD frame and that crosmember was mounted in the BB posistion so I used that for a starting point. I think I can let it in the frame, it should clear the front driveshaft. The front crossmember is the 73-up swaybar one.
Later Willis
Old 02-12-2006, 11:57 AM   #4
BobS
BobS's Avatar
Willis,
Do you have any closeups of where the rear hangers for the front springs mount in relation to the rear (bellhousing) crossmember?
Bob
V-6....only GMC Trucks have it!
62 GMC W5000 NAPCO-V6
65 GMC 2500 NAPCO Panel-V6
66 GMC 1000-V6
66 GMC 1500-V6
67 GMC K1500-SBC (originally a KM-V6)
68 GMC C1500-V6
68 GMC C1500-V6
68 GMC Suburban C2500
70 Chevy K20-SBC
71 Chevy C30 Longhorn-SBC
72 GMC Suburban C1500-BBC
72 Chevy C10-SBC
72 GMC C5500-ToroFlow Diesel
BobS is offline   Reply With Quote
Old 02-12-2006, 04:29 PM   #5
What springs will you use,the`73-ups?Keep us posted,looks good so far.
Old 02-12-2006, 06:24 PM   #6
67-72williso
Smile Re: 4X4 Frame Progress
I will be using 67-72 front springs. I just measured the 73-up from the center of the axle front, to mount the swaybar crossmember. I think it was like 15" front to center of the front swaybar brackets.
Bobs
I`ll try to get you some pictures this week. Also there is a 69 GMC 2500 custom camper V-6 at the local bone yard with motor, NP-435 trans,Dana 60 leaf rear, Its a parts truck. Still has the fender emblems on it.
Old 02-12-2006, 07:03 PM   #7
4bynut
4bynut's Avatar
Looks good!! Real interested in seeing how the rear leafs mount up.
2007 Chevy 2500HD crew cab, 4x4, duramax w/Allison trans.
2001 Chevy ZR2 Ext. cab 4x4 (DD)
1967 Chevy SWB 4x4, BBC, Th400, NP205, 6" lift, and 35's (In Process)
1970 Chevy Blazer 4x4, BBC, TH400, NP241, 6" lift, and 38.5 boggers in front, 44 boggers on the rear ( mud racer project)
4bynut is offline   Reply With Quote
Old 02-12-2006, 10:43 PM   #8
4x4Poet
Originally Posted by 67-72williso
That crossmember your talking about is the 2 WD bell housing crossmember. This was a 2 WD frame and that crosmember was mounted in the BB posistion so I used that for a starting point. I think I can let it in the frame, it should clear the front driveshaft...
You've pulled the cradle crossmember out of a 2wd frame and installed a 73up X-member to throw in a BBC and you'll also switch to leaf springs with a 4x4 conversion???
Excellent!!!
Old 02-12-2006, 10:56 PM   #9
BobS
BobS's Avatar
If you get a chance to grab those fender emblems for a decent price, I'd appreciate it!
Bob
66 GMC 1000-V6
66 GMC 1500-V6
68 GMC C1500-V6
68 GMC C1500-V6
70 Chevy K20-SBC
72 Chevy C10-SBC
Old 02-13-2006, 02:46 PM   #10
Yukon Jack
Yukon Jack's Avatar
Is interesting how I too missed this post - must have been cause it was during Christmas break. Interesting swap, keep us informed.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
