Old 12-26-2005, 06:14 PM   #1
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
heater core
The PO had put a ball valve in-line for the incoming hot water to the heater core. I'm not sure why he would of done this, and it has always been closed. Is it bad to not have water running through there? I'm tempted to open it, but I'm a little nervous about hot water pouring into the cab. There must of been a reason he would have done this..... Any ideas? The original heater controls were broken, and I just got a new heater control for Christmas and installed it, and since the weather has been a little cool (for Florida standards) I wanted to have everything operable. Here's a pic to show where the ball valve is:
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 12-26-2005, 06:20 PM   #2
Sweet72
Sweet72's Avatar
Re: heater core
If the heater controls were inoperative the damper/door that controls airflow across the heater core may have been stuck open, so the PO installed it to keep heat from boiling him out of the cab in summer. A quick fix to keep the heater core cool. The heater core may be corroded since the coolant in it has been stagnant. Pull the hoses off the water pump and intake and flush it out both ways with a water hose.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 12-26-2005, 06:23 PM   #3
67Fleet
67Fleet's Avatar
Re: heater core
So it doesn't harm the engine to have the line shut off there? Doesn't it impede water flow through the intake manifold?
-Bret
Old 12-26-2005, 06:39 PM   #4
mrein3
mrein3's Avatar
Re: heater core
Factory AC trucks have a vacuum controlled shut off valve in the same spot. Some old school folks put in the manually operated one like you got. Open it up. Next summer if you feel heat bleeding through, close it again.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 12-26-2005, 07:04 PM   #5
67Fleet
67Fleet's Avatar
Re: heater core
Cool, thanks guys!
-Bret
Old 12-27-2005, 12:25 PM   #6
farside847
farside847's Avatar
Re: heater core
Or, the core may leak and he put that in for a temp fix.... Look for leaks!
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 12-27-2005, 03:42 PM   #7
alf1096
alf1096's Avatar
Re: heater core
If it does leak I changed mine yesterday it was very easy but order the new gaskets for the blower moter from lmc and have someone help with the hood
1970 Short Stepside----Process of Restoring
1983 1/2 Silverado
alf1096 is offline   Reply With Quote
Old 12-27-2005, 10:22 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: heater core
I have always had issues with the hot air getting by the doors in the heater box, and have been looking at doing something like that, but not as bug and ugly though.
While there is a chance that this was put in becouse of a leak, odds are it wasn't. Normally when a leak is found, and the owner doesn't want to repair it, they won't go out and buy a $10 valve to block off an $18 heater core... they'd just run the hose straight from the intake to the water pump, that is free.
Old 12-27-2005, 10:55 PM   #9
Green Machine
Green Machine's Avatar
Re: heater core
Picture isn't very good, but I used a common brass ball valve with the handle cut down attached to the water pump to completly cut the heat in the summer.
Now this is not real pretty either, and I would like to find something that looks better also. I know some a/c cars had a vacuum valve mounted on a tube attached to the intake outlet, but not sure what appication that was. might be a cleaner install.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 12-27-2005, 11:57 PM   #10
walker
walker's Avatar
Re: heater core
If there is only one valve then a leak would still leak with the valve closed, as there is still water and pressure on the core, just no flow.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 12-28-2005, 12:00 AM   #11
kwmech
Re: heater core
The valve is on the return line back to the engine. Out of the intake and into the pump or radiator.
