09-12-2002, 12:49 PM | #1 |
292 to 454 swap info please
Hey all. I'm looking into changing my 292 (with manual trans) out to a 454. The donor truck ('78 1/2 ton) has an auto trans but I'd like to keep my 4-speed. Has anyone done this? TIA
Greg |
09-13-2002, 03:23 AM | #2 |
Are yuo gonna sell PS brackets if you have them?
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
09-13-2002, 05:26 AM | #3 |
72 style BB neinge mount and tree, 68-71 are more similar to 6 cyl ad SB mounts and tree:
http://groups.msn.com/ChevyTrucksfor...xtrastuff.msnw |
09-13-2002, 07:22 AM | #4 |
What are you gonna do with the 292?
I'm interested in the sheemetal: Valve cover, Timing gear cover, side/lifter panels and oil pan. That is you don't have any plans for the motor.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 09-16-2002 at 02:36 AM. |
09-13-2002, 08:24 AM | #5 |
Whys everyone want 292 Parts?When i had 2 running ones,complete out of trucks,i couldnt give away for free,well i guess i did when i dropped them in the dump pile.one had PS and even a Holley carb!
09-13-2002, 08:29 AM | #6 |
Oh to get motor to sit right use 68-71 or 72 BB towers,and use all the brackets and pullies off 454 it will be LWP so youll need to make some wires longer,your alternator will now be on the pass side,unless you buy the short pump stuff.Heres what a typical short pump conversion consists of
1.fan shroud 2.towers 3.ps pump and brackets 4.alt brackets 5.pulleys etc. I have most all of this available,but youd be saving ALOT if you went with the long pump stuff,i have all that to,if you need any. |
09-13-2002, 01:31 PM | #7 |
thanks
Souns like this swap isn't all that bad; it's my first time tryng to change engines around so it should be a learning experience for sure. Thanks for the info. As for my 292, the truck ('69) is manual steering so no PS brackets, sorry and I'm not totally sure what I'm going to do with the engine once I have the 454 in there. I may plop it into the '78 and sell that as a complete truck but I guess if there was interest in buying it.....
What about locating the engine? (I'm still a few months away from actually doing this swap but I'm trying to get some homework in now.) And as for a source for the '72 mounts (I assume the ones in the '78 are no good to me) can I just scoop them from a wrecker or am I better of getting new ones/ should I grad poly ones if they're available? Again, many thanks, you guys rock Greg BTW thanks for the offers Desert Rat, I'll keep you in mind if I need stuff |
09-13-2002, 01:33 PM | #8 |
oops
sorry...the last part of my previous post might've been a little confusing. By location the engine, I mean locating it in the engine bay. Should I just get a cherry picker and loewr it into place, bolt it (temporarily) to the tranny and mark where i need to put the mounts? What about making the switch from 454+auto to 454+manual? Any trouble there?
Thanks again Greg |
09-13-2002, 01:43 PM | #9 |
Project Junkie! Fishing Poor!!
The bell housing crossmember is different for the 6 cylender trucks and will have to be changed. It also is located in the wrong spot and is shaped different where it rivets to the frame, so you can't just move the crossmember you already have. You will also need all new bell crank and related hardware and new front driveline half of the driveline. WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
09-13-2002, 04:37 PM | #10 | |
292 is a different story again, one is short and one is tall on 292 engines and one is in forward holes and one is in back holes good luck |
09-15-2002, 07:49 PM | #11 |
again, thanks for the replies. It sounds to me that it would be easiest to swap the driveline into the '69 (454 AND auto trans) since I need a different crossmember and clutch setup anyway. Hmmm....how badly do i want the 4 speed....
Are there interchange manual for this type of stuff? Greg |
09-15-2002, 08:03 PM | #12 |
Will the towers out of 73 up bolt into 67-72 trucks?My 67 also had a 6 banger and I'd to put a BB in it,but the towers and mounts have got me a little confused.I planned on useing 73 up parts .Will they work?
