Old 12-28-2005, 09:03 PM   #1
qksilver
73 crossmember in a 69. Motor mounts?
I am putting a 73-up crossmember in my 69 and need to know if I can use the 73-up motor mounts. I am swapping a BB into it. I have 67-71 BB mounts, 72 BB mounts and also the BB mounts for the 73-up crossmember.
I remember something about the later model being too tall. I am limited physically right now(hernia) and want to avoid a bunch of trial fitting. Would like to do it the first time.
Thanks,
Steve
qksilver is offline   Reply With Quote
Old 12-28-2005, 10:19 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 73 crossmember in a 69. Motor mounts?
That is a good question.
Personally, i would try to use the 73 & up ones. The 68 - 71 towers are a dime a dozen, but the mounts are expensive.
The 72 towers are worth quite a bit... sell them to the highes bidder on E-bay... the mounts are dirt cheap though.
The 73 and up ones I believe are dirt cheap, and the mounts are also.
Old 12-28-2005, 10:36 PM   #3
qksilver
They looked the same, I just wasn't sure. The 72 sets I have are for my retirement! The two reasons i am using the 73 crossmember is the mounts and suspension parts cost being cheaper, plus I think the oil pan can be dropped easier.
Thanks,
Longhorn man, after this one is done i will have a few questions about my 72 bb longhorn.
Old 12-29-2005, 04:36 AM   #4
junkyardjohn
junkyardjohn's Avatar
If You Are Using 73 Up Crossmember, By All Means Use A 73 On Up Towers & Motor Mounts. They Will Work Fine, Without Any Height Issuses. 73 On Up Motor Towers Are Only Too Tall When You Try To Crossbreed Them With 67-72 Crossmembers. I Have Put A 75 Frontend Under A 71 & A 85 Crossmember Under A 69, Both With Big Blocks. John
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 12-29-2005, 01:49 PM   #5
qksilver
perfect, thanks/////////////
