12-31-2005, 12:20 AM | #1 |
front shaft length?
were 3/4 ton front shafts longer than 1/2s i got a new one with my half ton went to put it on my 3/4 and it is shorter by a couple inches
common sense isn't so common anymore |
12-31-2005, 12:43 AM | #2 |
Re: front shaft length?
Depends on your tranfer caseon which shaft you need. I cant remember which one is which but a 203 and a 205 have different shafts.
Chuck '85 Chevy Silverado 4X4 '91 Chevy 4X4 Suburban http://www.cardomain.com/memberpage/545941 |
12-31-2005, 01:57 AM | #3 |
Windy Corner of a Dirty Street
Shaft lengths are almost treading towards a personal question…
As mentioned above…it depends on your tcase…BUT..I would like to add that it also depends you’re your transmission. On my 78 K10, I went from the original TH350/NP203 to a TH350/NP205 combo. That cost me lengthening the rear shaft and shortening the front as well as changing the front shaft all together to mate to the 205. Then when I went from the TH350/NP205 to a SM465 manual/NP205 combo back in 1999, I had to lengthen the rear and shorten the front…..If I rember right.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
01-01-2006, 11:07 PM | #4 |
both my trucks are small block th350 and 205s but i never did look under the 1/2 ton to see if it was the right shaft for it either just know it is shorter than the 3/4 ton shaft that needs replaced due to worn splines
01-02-2006, 01:23 AM | #5 |
front shaft?
were all th350/205 shafts the same for all years length and u joint size and what are they worth new / used and rebuilt
01-02-2006, 04:23 PM | #6 |
Please keep the topic in one place. It is far easier to follow for everyone involved.
