Old 01-01-2006, 12:17 PM   #1
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
What should the pinion angle be?
Im gonna be installing my four link in a couple of hours and just thought I would double check what the pinion angle should be before I put it on? Ive heard that it should be 4-5 degrees down and read in another thread that if you within 2-3degrees that it would be fine. Is all this true?
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 01-01-2006, 12:55 PM   #2
larry may
Re: What should the pinion angle be?
Last one I set up was in a drag race car. We went 7 degrees below center . Seemed to hook up best there. Also is 9 inch ford differential. Good Luck. Larry
larry may is offline   Reply With Quote
Old 01-01-2006, 01:20 PM   #3
Bowtie67
Bowtie67's Avatar
4 to 5 degrees is what is recomended on the street, what 4 link did you get? Also make sure your lower arms are even and parellel to the ground with the vehicle setting at the diesired ride you are looking for.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
Old 01-01-2006, 01:39 PM   #4
bagged69c10
The suicide doors super lift triangulated 4 link 36 in lower bar and 38 in upper adjustable bars
1965 c-10 long bed
1993 Sierra x-cab
Old 01-01-2006, 02:03 PM   #5
dwcsr
Hollister Road Co.
dwcsr's Avatar
This is a good article on pinion angle.
http://carcraft.com/howto/91758/
4 links should not be more than 3* or no less than 1*. ladder bars and springs are different. If you go to small or to large on the degree you'll have a vibration while driving, racing is different. The Triangulated 4 bar is a pain to correct afterward, you have to cut and rethread the bars so git it right the first time and tac everything before you do a full bead.
Tac the axle housing to the jack stands so it doesn't move.
This is mine on a 58 3100 but its the same idea
Mine is a pinion centered rear and yours most likely is not so thats the reason some thing look so close on the right side of the rear housing.
http://www.ridetech.com/projectview....2785&SUBSYS=CC
