Old 01-01-2006, 05:41 PM   #1
case_bt
case_bt's Avatar
electric fan temp switch?
I want to hook up my fan to a electric temp switch If any of you guys used one from another car or know a part # for one I can buy at an autoparts house It would be great
case
case_bt is offline   Reply With Quote
Old 01-01-2006, 11:06 PM   #2
kelsfine69
18 Till I Die
kelsfine69's Avatar
Re: electric fan temp switch?
Heres an option..
http://www.flex-a-lite.com/auto/html...cessories.html
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 01-01-2006, 11:22 PM   #3
cdyblu
cdyblu's Avatar
Flex-a-lite Part# 31147-Adj. Temp Sensor
Turns fan on/off at the desired temperature. Dial-adjustable 180-240F. Gives the freedom to set one temperature for occasional high-demand use, then reset for highway or day-to-day driving.
This is the one I use, works great!!
cdyblu is offline   Reply With Quote
Old 01-02-2006, 11:24 AM   #4
formula_raider
Case, you might try Old Air Products. They have (2) sensors that come on at different temperatures and screw directly into a coolant port. They are out of FT Worth right off of 35W, that may be an option if you happen to be around that area.
formula_raider is offline   Reply With Quote
Old 01-02-2006, 12:06 PM   #5
farside847
farside847's Avatar
Cool! Do you mean they screw into the drain plug on the radiator?
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 01-02-2006, 05:51 PM   #6
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
i thought i read somewhere you could use a temp sensor from an 80 something firebird that screwed into the manifold. I am getting ready to do this in the next few days as well
chevyguy_72 is offline   Reply With Quote
Old 01-02-2006, 09:35 PM   #7
formula_raider
Dang...I cant find my catalog or I would give you a part number but they are 3/8" NPT temp switchs that screw into either a intake manifold port or head port, just like where you would put a temperature sensor for a gauge. When the engine reaches a certain temp it complete the circuit, when the temperature lower to a certain temp it opens up and shuts the fans down. There are (2) versions; one comes on at like 185 and shuts down at like 170 the other one is a higher temp. Give Old Air a call they are easy to deal with and I believe the sensor is about 22.50.
Old 01-02-2006, 09:52 PM   #8
case_bt
case_bt's Avatar
would the temp switch go on the groung side of the relay or the switch side?
Old 01-03-2006, 12:17 PM   #9
chevyguy_72
Vintage Evil
i believe it would be the switch but am unsure. I am sure someone on here knows.
Old 01-03-2006, 12:37 PM   #10
formula_raider
The +12V switched side of the relay.
Old 01-04-2006, 10:00 AM   #11
383 Stroker
383 Stroker's Avatar
Painless makes a sending unit that screws in the intake or head. Summit & Jegs sells them. The part number for the 185*/170* is PRF-30111 . I use it and it works good. The ground wire from the relay runs through it.
Video's of my Truck Racing
1967 C-10, 383ci Sbc, TH350, 3200 stall, 3.73 gear
383 Stroker is offline   Reply With Quote
Old 02-04-2006, 11:19 PM   #12
Chevrolet4x4s
Chevrolet4x4s's Avatar
Any one know of a way of having them automaticly turn on at 170-175 and off in the 150 range?
Shane
1993 K1500 350 5 speed
1985 K10 Silverado Vortec 406 5 speed (in body shop)
"I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been
No, I ain't broke I'm just broken in"
1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle )
Member#20327
Chevrolet4x4s is offline   Reply With Quote
