Old 01-07-2006, 02:52 PM   #1
blazerparts
No,I DON'T have Tourett's
blazerparts's Avatar
HEI incap coil bad?
Truck ran like a scalded dog last night. This morning no ignition spark. Could the coil have failed? any way to test? comments? ideas?
thanks
'72 K5 CST 350/350 Daily Driver
'69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck
'69 GMC 2500 L6292, 3spd beater
blazerparts is offline   Reply With Quote
Old 01-07-2006, 05:33 PM   #2
jhow66
jhow66's Avatar
Re: HEI incap coil bad?
More than likely module. Take it with you and the parts place will test it for you.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 01-07-2006, 05:44 PM   #3
corn
I agree^
corn is offline   Reply With Quote
Old 01-07-2006, 06:28 PM   #4
bighead
My old HEI equiped 79 Chevy PU crapped out on a cold cold night in October several years ago on the way to the Chickasha, OK swap meet. Thankfully a guy stopped to help and he had with him a cap and coil. I popped it on and was running in minutes. He told me, and I followed his instructions to always carry a spare cause they were know to fail when you need them the most.
bighead is offline   Reply With Quote
Old 01-07-2006, 06:56 PM   #5
shifty
Questionable
shifty's Avatar
Just make sure you hook up all three wires for the coil. Some people only hook up the two that come attached to the coil. If you don't hook up the third you'll burn the coil up.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 01-07-2006, 07:32 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
It's a good policy to change the module and coil at the same time.
Sometimes, the coil will burn up several modules before it fails itself. It makes the mechanic look bad because he keeps changing the module and it fails soon after. Changing both coil and module at the same time covers both bases and helps make sure you don't get stranded.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-07-2006, 09:18 PM   #7
blazerparts
Thanks all. I changed the module and the coil and it fired right up.
Old 01-07-2006, 09:18 PM   #8
blazerparts
Old 01-07-2006, 11:14 PM   #9
krue
Designated A-hole!
krue's Avatar
Good deal.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 01-08-2006, 12:51 PM   #10
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
yep I just went through this ordeal also...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 01-08-2006, 01:01 PM   #11
cableguy0
all ignition parts wear at about the same rate. running worn out plugs or wires and cap and rotor will stress the coil and module both. its good practice that if the parts on there arent fairly new to just do a full tune up when you change the coil and module
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
