01-09-2006, 02:54 PM | #1 |
Addicted to Chevy
OK Fellas- Come through for me once again
alright. i have just replaced my 350 with a rebuilt one, and now i need some help hooking it all back up. everything is done except for my clutch linkage. i have a sm465 (4speed) muncie tranny and the linkage confuses me to the utmost extent. if anyone has some pics that would help me i would be very appreciative.
01-09-2006, 03:50 PM | #2 |
Professional Grade
Re: OK Fellas- Come through for me once again
Its actually a very simple thing to hook up
The zbar has an end with a bolt in it that goes to the frame side, and the other side slides onto a ball on either the tranny housing, or the engine (dunno when they switched) Either way, you should have a bar that sticks up on the driver's side of the truck for the clutch pedal rod to hook up to, and a bar that sticks down on the other side that the rest of it hooks up to. I'll need to try and hunt down some pics of how the bottom part hooks up, as it has been almost a year since I last looked at a z-bar linkage...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
01-09-2006, 07:36 PM | #3 |
Try This Link!
http://arrc.epnet.com/autoasp/framerq.asp Without Hydraulic Clutch Disconnect the return spring at the clutch fork. Rotate the clutch lever and shaft assembly until the clutch pedal is firmly against the rubber bumper on the brake pedal bracket. Push the outer end of the clutch fork rearward until the throwout bearing lightly contacts the pressure plate levers. Loosen the locknut and adjust the rod length so that the swivel slips freely into the gauge hole. Increase the rod length until all lash is removed. Remove the swivel from the gauge hole. Insert the swivel in the lower hole in the lever. Install two washers and the cotter pin. Tighten the locknut, being careful not to change the rod length. Reinstall the spring and check the pedal free travel. It should be 1 3⁄8 -1 5⁄8 inch. Hope this helps. - Dave
2003 Silverado K1500 Z71 - Arrival Blue 1973 K5 Cheyenne Blazer 350/TH350/NP203 Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift. RETIRED: 1980 Scottsdale 4x4 Founding Member: "TILT WHEEL BELLY." Club |
01-09-2006, 07:46 PM | #4 |
Professional Grade
That'd be what I was looking for Dave!
This outta get you going man
01-10-2006, 08:47 PM | #5 |
Addicted to Chevy
thanks guys! always got what i need! and i would like to run some numbers for my engine- what numbers from what places would one need to do such a thing?
01-10-2006, 09:19 PM | #6 |
Professional Grade
Assuming an installed engine, the casting number is found at the back driver's side of the engine, just infront of where the tranny bolts to it.
I think there is another way to identify it as well, as that can be kinda tough to see, but I'm not sure how. Check www.mortec.com -- They should have instruction on where to find the casting numbers, and what they mean there
