Help!!!
I noticed white smoke coming out of my tail pipe at startup just out of the passenger side it smelt like antifreeze. I have noticed water missing from my radiator and have been refilling it and the truck runs fine. Well to make a long story short I took my spark plugs out and turned the engine over and water is coming out my #7 and #8 cylinders sparkplug holes more out of 8 than 7.
I did the normal trouble shooting the facts no water in oil oil looks good antifreeze smell in exhaust engine has about 2500 miles on it I did not retorque my heads What are the likely hood of it just being the intake manifold gasket? what the chance of both head gaskets blowing? |
![]() Join Date: Sep 2005
Re: Help!!!
blown head gasket sorry dude looks like it time for a top end rebuild only thing i know to do that unless the blocks cracked
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 01-09-2006 at 09:41 PM. |
#3 | |
![]() Join Date: Aug 2001
Re: Help!!!
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
Just hang'n around
Re: Help!!!
I'm surprised it's not over heating. Yup, head gasket because there is no water flow through and around the intake manifold.
Driving a '68 Chevy C20 and a '93 Astro Van. Lots and lots of mileage that I deduct each year. |
No,I DON'T have Tourett's
Re: Help!!!
nothing like the sweet smell of antifreeze in the exhaust.......
'72 K5 CST 350/350 Daily Driver '69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck '69 GMC 2500 L6292, 3spd beater |
Re: Help!!!
Could be a few things, pull the head and there will be your answer
Re: Help!!!
after pulling the distributor and intake I was getting water in my oil nice yellow like mixture pulled the head off # 8 had water in it. Would you think the rings would be ok? before i pulled the head off I checked compression it was like 120-130 psi. heres some pics for you guys. this was my first engine to build and it won't be the last.
Re: Help!!!
rings should be fine now just check the deck and the face of the heads and block make sure everything square. install new head gaskets and get the intake gasket on good and put her back together and hope eveything goes okay
Re: Help!!!
could i get some suggestions on what type of head gasket to buy I don't want crap and install tips would be great.
Re: Help!!!
perma-torque gaskets by fel-pro are good gaskets
#11 | |
I'm watching you!
Re: Help!!!
2012 Chevrolet Silverado 1500 Z71 4WD 1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP) 1992 Chevrolet S10 - LS swap project 1968 Chevrolet C-10 longbed fleetside - sold ![]() |
Re: Help!!!
be sure to put thread sealer on all of your head bolts. they all go to the water jacket. hope you get it going.
Re: Help!!!
what bore size gasket do i get my truck is 40 over they have different sizes
Re: Help!!!
with the felpro do i install them dry
#15 |
Re: Help!!!
Go Fel-Pro all the way, they are the only gaskets I use. Never had a problem in well over 100 engines
"We always have parts left over on a job this size" |
#16 |
Re: Help!!!
does anyone know what size bore gaskets to use my truck is 40 over but felpro has lots of different bore sizes?answered it myself part # 1003 they are good to 4.155 bore size
#17 |
Re: Help!!!
CASE... I'VE REBUILT MORE THAN A FEW MOTORS, & ONE LITTLE THING I ALWAYS DO IS USE FEL-PRO GASKETS. THEY ARE NOT THE CHEAPEST GASKETS YOU CAN BUY, BUT THATS OK... YOU DON'T WANT THE CHEAPEST ONES YOU CAN GET. ANOTHER LITTLE TIP IS SPRAYING BOTH SIDES OF THE HEAD GASKET WITH A COPPER HIGH-TAC & SEALANT PAINT (SEE PIC.) . JUST SPRAY IT ON BOTH SIDES & LET IT TAC UP FOR 4 OR 5 MINUTES BEFORE YOU INSTALL THEM. THIS REALLY SEALS EM UP & MAKES THEM STICK LIKE SH!T TO A BLANKET.
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST Last edited by junkyardjohn; 01-10-2006 at 08:42 PM. |
#18 |
Re: Help!!!
the perma torque I bought said they need no sealant
#19 |
Re: Help!!!
