#151 |
Westsyde Truck & Rod
Re: Custom Chassis with canti setup
Frame looks awesome!! Nice work
#152 |
All Praise RANDY!!
Hey Jr... that shiznit looks sweeeet! I likey alot! By the way, the testosterone levels have FINALLY increased in our household!!!! Thats right, daddies swimmers have produced a male offspring!
Now I just have to await the dreaded snip-snip myself... ![]() Bill G |
#153 |
Congrats on your baby boy!!!
#154 |
cornutz-or is it nonutz? congrats on your last!
#155 |
Cornutz, if they cut your nutz I think Valley could weld you up some improved nutz out of steel. Or, maybe after driving your truck with that frame under it you do not need any nutz, they just assume you have big ones.
#156 |
Trucker.
Best looking chassis I've seen, hands down.
#157 |
Seņor Member
Any thoughts on this relatively simple back half? It would tie into the stock frame rails just under the cab.
And... any suggestions on something a little more lift-capable than bags in the stock locations? I don't know that I need something as complicated as valleycustom is doing here...
#158 | |
Please become a site supporting vendor to advertise a business in your signature. you can do so here Last edited by valleycustom; 01-23-2006 at 01:04 PM. |
#159 | |
Seņor Member
#160 |
Damn that frame is sick man... Keep up the bad ass fab. work man
#161 |
Well today I started on the exhaust. I was able to get most of one side finished. When I start on the other side the two pipes in the middle will goin to create a x over pipe. Enjoy
Please become a site supporting vendor to advertise a business in your signature. you can do so here Last edited by valleycustom; 01-25-2006 at 12:38 AM. |
#162 |
Some more
Please become a site supporting vendor to advertise a business in your signature. you can do so here |
#163 |
Just Don't Stop!
![]() Join Date: Feb 2004
are you using a V-band clamp there? expensive stuff but way nice!
1968 C10 build in process TT LSA/6L90e/9" |
#164 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Damn that is looking sweeet...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#165 | |
#166 |
Seņor Member
Is the exhaust tude welded to the frame???
#167 | |
Son Of Gravel Man
looks more like a notch in the frame for the exhaust.
Daily driven 70 C10 longbed Its a work in progress ![]() Quote:
#168 | |
Please become a site supporting vendor to advertise a business in your signature. you can do so here Last edited by valleycustom; 01-25-2006 at 09:59 PM. |
#169 |
Here are some close up pictures. I'm not finished welding it up.
Please become a site supporting vendor to advertise a business in your signature. you can do so here Last edited by valleycustom; 01-25-2006 at 10:07 PM. |
#170 |
PROJECT 7DEUCE
That is gonna be a tight azz fit...
#171 | |
#172 |
That looks great. Nice work. I used the same manderals to do my 3". Not as trick though....I only have a 1/4" around the frame to 3" tube and it never hits. I have poly motor mounts and tranny mount so there is not much motor twist.
I wish I could have got a X pipe in there but the H will be alot more doable. It's kinda going to be more of a U because of where the duals are placed right now there is no horizontal connection that could work..
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
#173 |
All I have to ask is; Is there anything you can't do?
I think I couldnt be more amazed after each set of pix you post, but everytime I find myself more amazed! Very nice work! Did you bend all your exhaust or are they pre-bent pieces? If you did it your self what gauge steel did you run? Keith |
#174 |
LOOKS GOOD! My only question is why not run it straight and go through the frame up ahead rather than make that 90 turn to come through?
#175 | |
