Old 01-11-2006, 10:34 PM   #1
john@thepier
john@thepier's Avatar
Bolt in solid motor mounts- any recommendations
I am putting a 408 stroker small block into my 70 swb. I will be building the motor over the next week or two. I am now just thinking I'll need to up grade the motor mnts. as well as all the other things. Anyone know of a bolt in style for our trucks? or will I need to engineer something my self. Thanks
john@thepier is offline   Reply With Quote
Old 01-11-2006, 10:57 PM   #2
71Dragtruck
71Dragtruck's Avatar
Re: Bolt in solid motor mounts- any recommendations
Prothane makes a performance bolt in, part #7-509.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 01-11-2006, 10:57 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here is a thread that may give you some info. Check shifty's post and his link to some swaps.VV
http://67-72chevytrucks.com/vboard/s...t+motor+mounts
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 01-11-2006, 11:19 PM   #4
john@thepier
71 DRAGTRUCK have you had any experience with these? Estimated torque for my build up is 540 ft.lbs. They look like they should work nicely. Any venders on the board with these for sale. Thanks
Old 01-11-2006, 11:28 PM   #5
71Dragtruck
I have a set ready to go in with my new motor, they look good and have a internal lock system so they can't pull apart. I'm going to use them on a 640hp. 620flb. BBC plus nitrous, so I sure hope they perform well.
Sponsored by:
Hard Candy Customs
Old 01-11-2006, 11:30 PM   #6
john@thepier
Everyone wish us luck!!!!JOHN
Old 01-12-2006, 04:10 AM   #7
carl609
carl609's Avatar
you should use a solid trans mount also if you use solid motor mounts.
carl609 is offline   Reply With Quote
Old 01-12-2006, 07:37 AM   #8
Bowtie67
Bowtie67's Avatar
Not sure why you are going with solid mounts, if its going to be pretty much a drag truck only I could see it, but if it is more street I would look at poly mounts and use a chain or cable with a slight bit of tension on the drivers side, I have never broke a mount doing this and it works real well. Do not make the chain real tight or you will feel the engine vibration, just a very light tension so that when the engine starts to TQ it will tighten up.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
