Just an Old Mr Goodwrench
Has anyone here ever replaced the visor mounts on their truck? Is there a trick to remove the clip holding the spring on the visor arm? Thanks!
1969 CST 20 Longhorn 1970 CST 20 Fleetside 1991 Jaguar Sovereign 1992 Mazda Miata |
67-72 Addict!
I think it is pressed on at the factory. I usually just pull the rod assembly out and replace the whole thing.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
#3 | |
If you spray along the shaft so that penetrating fluid will flow inside, you can usually pull the shafts out with a back and forth twisting motion. The sleeve that the shaft holds the visor on keeps it in place by friction only, (there are no clips or retainers).
I have not had any that the shaft could not be removed after it was soaked down. Jim |
Duh . . .
Senior Moment
![]() Join Date: Mar 2002
I have a couple of spares you can have for the cost of shipping.
Send me you zip for cost estiment
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
