Help...New Early Classic 4" drop springs
I'm trying to put in my new springs and I'm not sure which end goes up or down. It has been a while since I took the old ones out. Here a picture please help!
68cst_ss490
Quick question???? Do you need to c notch your frame with 4" drops in the rear????????
Dean edmonton,canada a winter wonderland 2005 Chevrolet Avalanche LT cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers. http://www.cardomain.com/ride/3090973 |
Not at all. EC says that 4" is on the boarder line when it comes to repositioning the rear shocks but I am going to try it without repositioning at first.
68cst_ss490
cool when the time comes I want to do a 2/3 or a 3/4 to my 68 not sure which yet
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
It shouldn't matter whitch end is up.. Both ends should be the same, because they require the same clamps. The front ones are the ones that have different ends. WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
I'm doing a 2/4 because they tell me that that's the max I can get away with on the front without drop spindles. 3" with just springs will cause negative camber (which means that the upper control arm runs up hill). This will cause the truck to have bump steer and act weird in hard corners.
Thanks WES now its off the computer and back to the garage to finish the rear suspension. I'll have pics later. THANKS AGAIN!!!!!!!!!!!!!!!!!
67-72 Addict!
Estanley,
Do you have to buy shorter shocks for a 2/4 drop with springs?
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
You will probly be OK with the shocks that you have. What you will want to watch for is the angle of the shocks. The lower you go the greater the angle of your shocks. At some point you will want to relocate the brackets to bring them into a more stock possition for them to work correctly. My 67 panel has a 4-6" drop and the rear shocks are at too great an angle to be effective, so it is rather bouncy back there. WES www.ClassicHeartbeat.com
#10 | |
14.1 @ 96MPH
Project1970 - LS1 Swap Complete! ![]() |
