Old 01-19-2006, 10:12 PM   #1
hilljob26
hilljob26's Avatar
what causes this??
well,my dad put a new holley on his truck,he messed with it alittle bit,seems to run great,but now when he shuts it off,it deisels a little,how can he fix that,any ideas,its a new holley 600 that does not have adjustable floats,its called a next generation needle/seat,just doesn't look right without that nut and screw on the top,but seems to work okay,just this little problem.....mike
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 01-19-2006, 10:53 PM   #2
northcountry67
northcountry67's Avatar
Re: what causes this??
It sounds to me like your timing is too advanced. It could be a combination of a number of things like the timing along with the idle too high. Check your timing with a light.
northcountry67 is offline   Reply With Quote
Old 01-19-2006, 11:09 PM   #3
Billla
Billla's Avatar
Billla is offline   Reply With Quote
Old 01-19-2006, 11:12 PM   #4
Novaguy73
Novaguy73's Avatar
Ill third that...
-73' Nova 350 5-speed 9"rear, Runs 11's drives anywhere...
-72' C10 350 Auto 12 bolt, runs 19's?? drives to work!
Novaguy73 is offline   Reply With Quote
Old 01-19-2006, 11:25 PM   #5
crazy longhorn
Fabricate till you "puke"
Call me #4 on that! Try setting the idle speed down, & see if that helps(assuming the timing was not changed, & there was no prob before) L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-20-2006, 12:06 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
third choice, it may be a little lean.
If timing is good, and idle speed is good, fatten up the mixture a bit.
Old 01-20-2006, 01:37 AM   #7
cduster
I'm going with mixture also.
Dan
Good Judgment comes from experience.
Most experience comes from bad judgment.
cduster is offline   Reply With Quote
Old 01-20-2006, 01:43 AM   #8
cypress TX 72
Saving one 72 at a time!!
cypress TX 72's Avatar
Timing !! (I'm with the other guys -I guess #5)
Try retarding it a little
cypress TX 72 is offline   Reply With Quote
Old 01-20-2006, 02:00 AM   #9
krue
Designated A-hole!
krue's Avatar
Check idle first.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 01-20-2006, 06:43 AM   #10
mike nutt
69fatmotor
mike nutt's Avatar
good call everyone!
mike nutt is offline   Reply With Quote
Old 01-20-2006, 07:42 AM   #11
hilljob26
hilljob26's Avatar
right on,thats what i needed to know,we never touched the timing,but will look into it.......mike
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 01-20-2006, 11:16 AM   #12
Longhorn Man
If the timing was never touched... then it should be fine... or good enough anyways.
Idle speed... it would be noticeable IMO... 850 RPM isn't going to do it, we're talking like 1000 RPM.
So that leaves mixture.
Old 02-10-2006, 03:58 PM   #13
68/72parts
Check your idle speed first and set it to spec. And see what happens. Then check your timing just like the last few replies. Generally it will run on if your idle is to high, when its set at a higher than norm idle the throttle doesnt close enough to stop the air and fuel flow and the truck will continue to run. Make sure that your throttle linkage is set properly as well especially if you changed from a different style carb!! Just my 2bits..
68/72parts is offline   Reply With Quote
Old 02-10-2006, 04:12 PM   #14
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
If you just replaced the carb. It is very likely a linkage problem. I went two barrel to quadrajet. The linkage hung up and kept the throttle from closing. It took 6 months of messing with throttle and timing adjustment before I solved it by adjusting my thottle linkage bracket.
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
Old 02-10-2006, 09:33 PM   #15
Sweet72
Sweet72's Avatar
Stock carb more than likely had a idle stop solenoid to close the throttle plate completely with the key off. If your holley throttle isn't closing as somebody already mentioned it will deisel with the key off.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 02-10-2006, 11:16 PM   #16
rkarr
rkarr's Avatar
I agree.
if she's lean, she'll do that...
Avatar is a pic of "Before"... Just wait..
1969 Fleetside:
Shortened frame for SWB, ECE 4-6 drop. ECE SS tank. All new ECE suspension. Rebuilt 12 bolt 3:73 with Eaton Posi. Front and rear disc brakes. Ramjet 350 and 700r-4 trans.
20" Centerline wheels with Kumho 295/45/20 tires (I hope they fit).
Progress pics: http://s44.photobucket.com/albums/f2...uck/?start=all
Seriously... It's nothing a large dose of cash can't fix... Right? After all, I can't take it with me when I go... Just gotta have enough to get there!!!
rkarr is offline   Reply With Quote
