Old 01-20-2006, 12:53 AM   #1
shifty
Questionable
shifty's Avatar
3spd column help
Hey, I have a 3spd column on my '68. The column is really plain and I want to dtrip the 3spd stuff off it and remove the collapsbile part of the shaft to refurb it, but I need some help.
Here is a big picture of what I'm working with:
http://satellitehead.com/images/68ch...swap%20017.jpg
How do I take that middle piece (intermediate shaft?) off? Where it connects to the column near the 3spd linkage, there's a thick washer that seems to be spring loaded. How do I get that off without it flying off and how do I get it back on?
Any tips on removal and reinstallation are appreciated.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 01-20-2006, 02:04 AM   #2
Green Machine
Green Machine's Avatar
Re: 3spd column help
You need to remove the whole column from the truck to operate on it. You will need to start at the rag joint at the steeering box and disconnect that and everything conneted or holding it in and remove it from the truck.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 01-20-2006, 02:08 AM   #3
shifty
Questionable
shifty's Avatar
rag joint is already off
ok, so, forget i mentioned the 3spd stuff removal. how do i get that intermediate shaft or whatever out? there seems to be a spring-loaded washer or something at the cab end of that shaft.
Old 01-20-2006, 09:04 AM   #4
junkyardjohn
junkyardjohn's Avatar
THERE IS A BOLT (ABOUT 3/8") HOLDING THE INTERMEDIATE SHAFT TO THE SPLINED AREA OF THE STEERING COLUMN SHAFT. PRETTY WELL SELF-EXPLANITORY. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 01-20-2006, 09:27 AM   #5
l1n1b1
67 Shortstep
Shifty,
I just did this this past weekend. If you have manual steering, the steering shaft will be one piece; you'll have to remove the steering wheel and the whole shaft will slide out the bottom. May be tricky getting it by the gearbox if it is still on. I left the shaft attached to the manual gearbox & removed the whole shootin' match because I was converting to power steering.
Now, if you already have power steering, the steering shaft is two piece. You'll need to remove the bolt that John mentioned, spead open the clamp that the bolt went through, & take a hammer and tap on the "universal joint" just below that big flat washer & spring. Don't worry, ther's not that much tension on the spring. The steering shaft will seperate at the clamp you spread apart.
Hope this helps!!!!
Bryan
67 SWB Step
69 LWB CST
71 LWB
94 SWB Step
05 1500 Dodge P/U
Adapt, Improvise, Overcome
l1n1b1 is offline   Reply With Quote
Old 01-20-2006, 12:03 PM   #6
shifty
Questionable
shifty's Avatar
Ok, I'm not seeing a splined area. I see the bolt+clamp in question, a thick body style washer and a spring with heavy tension pushing the washer into the clamp.
Old 01-20-2006, 12:14 PM   #7
l1n1b1
67 Shortstep
Is it manual or power steering?
67 SWB Step
69 LWB CST
71 LWB
94 SWB Step
05 1500 Dodge P/U
Old 01-20-2006, 12:20 PM   #8
shifty
Questionable
shifty's Avatar
manual
i'm converting to power right now w/the LS1/T56 swap. the rag joint end is disassembled, plastic rivets are removed and shaft is half-collapsed. just looking at the assembly and was asking in chat about how to detach that top end without that spring+washer going flying and nobody knew. it's not obvious what's underneath there, so i was looking for some answers from someone who's been there and done that.
it might seem simple, but i've never done it before and i am not the kinda person that just loosens up bolts when tensioned springs are involved. things like that break teeth (ball joints), send parts flying (lost) or make something impossible to put back together (which looks like what would happen in this case).
Old 01-20-2006, 12:31 PM   #9
l1n1b1
67 Shortstep
Okay, if it is the original manual steering in the 68, pull off your steering wheel and the whole shaft will drop out the bottom of the column housing. Be prepared, that thing is loooooooong! All the washer & spring does is hold a little pressure against the shaft bearing in the lower portion of the column housing....
67 SWB Step
69 LWB CST
71 LWB
94 SWB Step
05 1500 Dodge P/U
Old 01-20-2006, 12:44 PM   #10
shifty
Questionable
shifty's Avatar
Cool. So, the bracket holding the column to the firewall doesn't need to be removed?
Old 01-20-2006, 12:48 PM   #11
junkyardjohn
Originally Posted by shifty
manual
AW GO AHEAD SHIFTY.. IT WON'T COME FLYING OUT... HONEST !! JOHN
junkyardjohn
DON'T RENT U-HAUL
Old 01-20-2006, 12:52 PM   #12
l1n1b1
67 Shortstep
That's a negative.....Now just to make sure I'm reading you right, all you want to do at this point is to remove the actual steering shaft, correct? If so, it's just like I said. Btw, I don't think you'll be able to use your original shaft when converting to power steering. I had to use the 2 piece shaft that came with the gearbox out of a 69....Slipped right into place...
Bryan
67 SWB Step
69 LWB CST
71 LWB
94 SWB Step
05 1500 Dodge P/U
Old 01-20-2006, 01:46 PM   #13
Bob Moore
Shifty - everything has to be removed. The bracket on the firewall, the bracket down on the floor where the column goes through from the cab, the rag joint, etc. It will be much easier to remove the column if you also remove the steering wheel. The one piece shaft you pictured is a pain. If you are changing to PS I would recommend using the 2 piece with intermediate shaft.
Hope this helps - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 01-20-2006, 02:25 PM   #14
shifty
Questionable
shifty's Avatar
Bryan
Mine matches right up - but I collapsed the shaft to get the new gearbox in and now I need to expand it and it's stuck...so I'm gonna rework it a bit...
Old 01-20-2006, 07:42 PM   #15
shifty
Questionable
shifty's Avatar
i loosened up the bolt. nothing happened. here's a picture:
Old 01-20-2006, 08:54 PM   #16
woodridge
woodridge's Avatar
Shifty, that is a one piece shaft, the spring only holds a few #'s of presure on the lower bearing. As sd above remove the steering wheel and it will slide out the bottom. To remove the column, cowl braket and seal must be removed. Good luck!
SEMA Network- Protect our Hobby!
71 C30 in pieces, starting to come together.
Click here for A Place For Tennessee Truck Enthusiest To Meet
woodridge is offline   Reply With Quote
Old 01-20-2006, 09:32 PM   #17
shifty
Questionable
shifty's Avatar
What is the purpose of that clamp then? How do I tighten it back up?
Should I just replace the damn column?
Old 01-20-2006, 11:22 PM   #18
junkyardjohn
SHIFTY .. NOW IS A GOOD TIME TO REPLACE YOUR STEERING COLLUMN WITH A VAN TILT COLLUMN. YOU CAN USUALLY PICK ONE UP AT A JUNK YARD FOR ABOUT $40 OR $50. IT'S A PRETTY EASY & WORTHWHILE UPGRADE, & YOU GOT MOST OF THE WORK ALLREADY DONE. JOHN
junkyardjohn
DON'T RENT U-HAUL
