Old 01-21-2006, 02:46 PM   #1
hilljob26
hilljob26's Avatar
looking for 3/4 ton diffs for swap
well,i think i am going to swap my half ton to a 3/4,but i need a good front diff w/ disc brakes and a good rear,i would prefer 3.73 or 4.10 gears,i guess maybe a dana 44 for the front and a 14 bolt for the rear,i dont know a whole lot about the 3/4 ton axles,but i guess its time to learn,if somebody close has some,let me know..mike
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 01-21-2006, 08:24 PM   #2
67-72williso
Junk/Daily Driver Club
67-72williso's Avatar
Wink Re: looking for 3/4 ton diffs for swap
For the front just use the Dana 44 and the gears you already have. All you need to change there is the hubs, rotors & lockouts. The rear you need to get an 8 lug full float to match your front gears. Hope this helps.
Later Willis
Daily Driver: 1970 C-20 400 sbc,sm-465,Dana 61 one ton SRW rear, 3.07 gears, locker.
There are three kinds of people: those who make things happen, those who watch things happen, and those who have no idea what happened!
67-72williso is offline   Reply With Quote
Old 01-21-2006, 09:15 PM   #3
hilljob26
hilljob26's Avatar
really,the front dana's are the same on 1/2 and 3/4
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 01-21-2006, 09:31 PM   #4
Southedisto
River life......
Southedisto's Avatar
The fronts are the same out to the knuckles. Some of the spindles are different, I think the early 70's were different. Someone will post for sure though.
Southedisto is offline   Reply With Quote
Old 01-22-2006, 01:22 AM   #5
86k10
I have a front D44 out of a 75 GMC K20 that's geared 4.10 and maybe a 14 bolt rear too.
98 Neon
97 Grand Prix GT
02 Grand Prix 40th Anniv.
86 GMC 5.0
77 Olds 98 6.6
REAL AMERICANS, DRIVE AMERICAN
86k10 is offline   Reply With Quote
Old 01-22-2006, 04:16 PM   #6
hilljob26
hilljob26's Avatar
really,what would you want for them,how far is that from say holdredge nebraska,i have family there
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 01-22-2006, 04:17 PM   #7
hilljob26
hilljob26's Avatar
do you know what that 14 bolt is geared at
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 01-22-2006, 05:54 PM   #8
krue
Designated A-hole!
krue's Avatar
No buying and selling here, I'm gonna move this.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 01-22-2006, 09:21 PM   #9
86k10
Bertrand is 15 miles west of Holdrege so I'm not to far away. The 14 bolt is 4.10 and has a factory posi. In fact it is in a truck I am driving now, I would like to change it to 4.56 I'll have to look over the D44 and make sure there is nothing majorly wrong with it and then i'll give you an estimate.
98 Neon
97 Grand Prix GT
86 GMC 5.0
77 Olds 98 6.6
Old 01-22-2006, 10:19 PM   #10
full foot notch
PM me, i have 8 lug outers already pulled
full foot notch is offline   Reply With Quote
Old 01-25-2006, 11:39 PM   #11
teeitup
Just like to part out trucks!!
teeitup's Avatar
Mike I just posted some for sale on parts board, Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 01-26-2006, 12:36 AM   #12
1967k30
1967k30's Avatar
I have a D44/14bolt combo w/ 4.10's for $450obo. Out of a 76' K20.I'm in NE as well.
01 2500 Duramax,6spd,4x4,Not stock. Estimated
550rwhp/1100rwfp on fuel only.
03 3500 Duramax,6spd,4x4,Pac-Brake,not stock Estimated 500rwhp/1000rwfp fuel only
67 K10 in many pieces
Little Brothers truck
67 K20 Cummins 12V/NV4500/205,
D60/Eaton w/ Detroit,37" Xterrains,crossover steering,
Future plans,Twins and lots of fuel.
1967k30 is offline   Reply With Quote
Old 02-11-2006, 04:17 PM   #13
4x4Poet
Front: What's been said about swapping in 3/4 ton stuff from the spindle out. I forget if the caliper brackets must also be swapped out.
Another upgrade is to install superior, 73up inner axles at the same time since they don't neck down as much and use a Spicer 760x joint (replacement for the old 297x) that is beefier than the original '72 260x joint. Consider alloy axles if the budget allows. Inner and stub Yukon 4340 axles can be had for both sides thru ringpinion.com/ for ~$450 with 760x joints plus shipping. Only absolutely necessary with a locker, IMO. Superior makes bling bling versions for much bigger bucks.
Rear: AFAIK, only 77up 1-ton GM trucks had SRW 14bFFs with the axle perches spaced to match 67-72s. I'm pretty sure that any other 14bFF must have its spring perches relocated to match the spring width of your '72 K10. No biggie if you can do it yourself or get the axle cheap so as to leave budgetary room for the short fab work. Proper angle is as important as width to stave of any castor-induced driveline vibration.
A cheaper option might be to source an Eaton H052 rear axle with 4.11 gears. It would also be light weight to retain a desent ride. Many 67-72 truck owners notice a tad more ride harshness once they install a 14bFF over an Eaton H052 or the 12-bolt. With either the Eaton or 14bFF, changing to disc brakes helps reduce the weight for a better ride, not to mention better stopping and easier maintenance (pad or caliper R&R).
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
