Old 01-23-2006, 10:31 PM   #1
My72Cheyenne
"Work in Progress"
My72Cheyenne's Avatar
Cab to filler neck gasket on '72
Hey guys,
I recently installed a new cab-to-filler neck gasket on my 72. I had the gas tank out when I did it, so it wasn't too bad. The new crappy quality rubber has already cracked and failed! I have another rubber gasket, but was wondering if the only way to replace it was to pull the tank again? Is there a way to replace it without having to remove the tank behind the seat? Aftermarket rubber products suck! Anyone out there have any advice?
Thanks,
Tom
72 Cheyenne 4x4, 350, th350, np205, factory air, tach, headliner, tilt
My72Cheyenne is offline   Reply With Quote
Old 01-23-2006, 10:38 PM   #2
Tim Christian
Tim Christian's Avatar
Re: Cab to filler neck gasket on '72
We have had the same problem on a lot we have sold. I have started offering GM ones also. just a couple of bucks higher.
Tim Christian is offline   Reply With Quote
Old 01-23-2006, 10:48 PM   #3
jhow66
jhow66's Avatar
Vasoline-put a thin flim on both pipe and inside of gasket and also the groove that fits in cab. Worked for me.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 01-23-2006, 11:43 PM   #4
409biscayne
409biscayne's Avatar
That just happened to me as well , i've used these lots of times before , but this is the only one that ripped , and i had the tank out as well . I'd like to buy the GM one , what's the deal .
Can-Am Motorsports
37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser .
64 Biscayne 409 2x4 4 speed 4.11 posi
65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon)
68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD)
409biscayne is offline   Reply With Quote
Old 01-24-2006, 12:01 AM   #5
gentry69
gentry69's Avatar
its possible but it sucks just take a couple of flat screw drivers and work your way around it if u got a nice paint job dont do like i did and slip and scratch the paint
gentry69 is offline   Reply With Quote
Old 01-24-2006, 12:35 AM   #6
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
I just put one in a 71 with fresh paint and the tank in the truck Not a nice job! I have also gone to just GM, but the 67-70 style from GM appears to be the same repro we have.
Anyway, I used mild liquid soap, diluted with water and pressed it in using wooden paint sticks...no screwdrivers or sharp metal tools. It does NOT like to go in when the tank is installed!
PICKMUP is offline   Reply With Quote
Old 01-24-2006, 12:40 AM   #7
jostrans68
Jostrans68
jostrans68's Avatar
dont use vasoline as it is petrolium based and will harm the rubber use Ky Jelly as it is water based Good luck. And I second no sharp items Jack
[CGTW Member
former 67-72 now with a 96 silverado
jostrans68 is offline   Reply With Quote
Old 01-24-2006, 12:46 AM   #8
jhow66
jhow66's Avatar
Now you tell me!! Oh well it was on my brother-in-laws truck anyway.
Old 01-24-2006, 08:21 AM   #9
70c10
67-72 Addict!
70c10's Avatar
I have done it the same way (liquid soap) as pickmup with no problems whatsoever.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 01-24-2006, 07:46 PM   #10
My72Cheyenne
"Work in Progress"
Thanks guys for the feedback. I'm thinking that I should get a GM gasket and throw the aftermarket. I do have new paint and definately don't want an accident. Perhaps removing the tank is the safe route.
Thanks,
Tom
Old 01-25-2006, 06:11 PM   #11
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I use Goop hand soap and a GM gasket. The hand soap will cling to the rubber and not run off. The GM gaskets are supple enough to be worked into place with two wooden popsicle sticks.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
