Old 01-24-2006, 01:53 PM   #1
northcountry67
northcountry67's Avatar
Lowering question
I have a 67 GMC shortened and I would like to lower it soon. I have heard of flip kits for the rear leaf set up. Can anyone give me any info on these flip kits? What do they consist of and how labor intinsive is the install?
northcountry67 is offline   Reply With Quote
Old 01-24-2006, 03:31 PM   #2
bwright
Re: Lowering question
A flip kit will have a "U" plate to mount the axle on top of the leaf springs and most of the time they'll come with new u-bolts.
The install is pretty easy. <simplified instructions> Just support the truck by the frame, take off the wheels, support the rearend, remove the leaf springs, install flip plate, reinstall leaves, etc.
bwright is offline   Reply With Quote
Old 01-24-2006, 03:38 PM   #3
Joe67
67 is sold
Moved to SUSPENSION
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 01-24-2006, 06:21 PM   #4
72MARIO
72MARIO's Avatar
A 73-87 kit can be made to work. Just need a little grinding done and it will work.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-28-2006, 12:51 AM   #5
northcountry67
How much drop will I get in the rear with a flip kit? Will I have to "C" notch the frame?
Old 01-28-2006, 11:55 AM   #6
72MARIO
72MARIO's Avatar
Axel is about 3 1/2+the thick ness of you spring pack that's your drop. Depending on where that gets you you might want to notch it. I have 2 1/2-3" of travel and no notch with my leaf truck I dont mind the way it rides.
2005 TAHOE DD
Old 01-28-2006, 11:56 AM   #7
72MARIO
72MARIO's Avatar
Just figured out what truck you have glad to see it's getting lowered
2005 TAHOE DD
Old 01-29-2006, 01:56 AM   #8
northcountry67
I think I have four springs with an overload. Did you remove any springs when you lowered?
Old 01-29-2006, 11:52 AM   #9
72MARIO
72MARIO's Avatar
I had them dearched 3"(sp) and a 2" drop shackle.(it will not clear a wood floor with out shaving the board) so if you have a wood floor go with 1.5 shackle.
I also removed the over load sprind that gave me 1" and this week I pulled the one with the clamp that holds the pack together that gave me a 1 1/4" now it sits nice.
In the end a axel flip would have been a better way to go. Just was not aware of the kits avaible and the simple mods that need to be made to get them to work out.
How much drop do you want ?
You are aware you can buy drop leaf spring right ?
2005 TAHOE DD
Old 01-29-2006, 12:34 PM   #10
northcountry67
No, I was not aware of that. Give me some info on what to look for. I was thinking of 4-5 in the rear and 3 up front.
Old 01-29-2006, 05:36 PM   #11
72MARIO
72MARIO's Avatar
Early Classics and CPP both have them http://www.classicperform.com
Pricey but simple
2005 TAHOE DD
