01-26-2006, 12:02 AM | #1 |
67-72 Addict!
Copper oil pressure line
I'm installing an aftermarket oil pressure gauge under the dash and I ran the new line from the manifold into the cab but have like 3 feet extra line. Should I just cut it short and keep the line straight or does it matter if I coil it behind the dash?. The reason I'm really asking is I can't find my tubing cutter
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
01-26-2006, 12:04 AM | #2 |
Jamie Hyneman is my twin
Re: Copper oil pressure line
Coil it.
You can always cut it shorter at another time.
Justin SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD Color Wiring Diagrams Now in High Resolution V8 and Cab and Cab and Chassis |
01-26-2006, 12:57 AM | #3 |
Coiling it in loops will help to relieve the vibrations so it won't crack as easy.
Same principal as some brake lines, and primer lines and fuel injection lines on airplanes. Dan
Good Judgment comes from experience. Most experience comes from bad judgment. |
01-26-2006, 01:21 AM | #4 | |
Avatar is a pic of "Before"... Just wait.. ---------------- 1969 Fleetside: Shortened frame for SWB, ECE 4-6 drop. ECE SS tank. All new ECE suspension. Rebuilt 12 bolt 3:73 with Eaton Posi. Front and rear disc brakes. Ramjet 350 and 700r-4 trans. 20" Centerline wheels with Kumho 295/45/20 tires (I hope they fit). Progress pics: http://s44.photobucket.com/albums/f2...uck/?start=all ---------------- Seriously... It's nothing a large dose of cash can't fix... Right? After all, I can't take it with me when I go... Just gotta have enough to get there!!! |
01-26-2006, 08:45 AM | #5 |
67-72 Addict!
Thanks. I will coil it behind the dash cluster. Does it matter if the line is looped vertically to save space?
01-26-2006, 09:00 AM | #6 |
you should actually coil it in the engine compartment between engine and firewall is where you have the vibration and flexing occuring causing the cracking of the pressure line
01-26-2006, 09:09 AM | #7 |
67-72 Addict!
Mine is coiled like that up to a connector. From that connector I ran the "new" copper line into the cab and that's why I have this left over line.
01-26-2006, 09:22 AM | #8 |
When you coil copper, lay a line of silicone across the coils (ties them together) - It changes the resonance of the coil and eliminates vibrational stessing that WILL cause the copper to harden and eventually, crack. Look at any refrigeration system with coiled up pressure lines - real easy pm and that's my .02
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
01-26-2006, 09:49 AM | #9 |
67-72 Addict!
Maybe I should have just used the plastic line that came with it.
01-26-2006, 10:33 AM | #10 | |
It's a catastrophic success.
01-26-2006, 02:04 PM | #11 |
I plan on swiching my plastic ones to copper. The plastic ones don't age very well, all the heat stresses them. If it blows or breaks it will make a real mess quick. Anyone one with a copper line have experience with their reliabiltiy?
01-26-2006, 04:26 PM | #12 |
This is how it looked from the factory. I took this off a 68 C20.....
1997 GMC Sierra Ext 1965 Mustang |
01-26-2006, 07:15 PM | #13 |
67-72 Addict!
Steve, my factory one looks identical. See the junction 6" above that spiral- I ran my new copper from that junction into the cab. Once inside the cab I guess I'll coil it up several times and hide behind the dash.
01-26-2006, 07:34 PM | #14 |
that'll work.......
