Tooloose
6 lug to 5 lug help please
It looks like my rear end measures 57 1/2". Another post I read said that 71 axles will interchange. My truck is a 68 and it shouldn't have the wider rear in it. Does anybody have a set of 71 to 82 axles laying around to measure the length on. Mine are 31' long. If mine are truly the wide ones I can buy 71 axles instead of redrilling.
A legend in my own mind!!! website: http://www.persmedequip.com/ '68 c10 (current project) http://67-72chevytrucks.com/vboard/s...ht=cherry+bomb '04 silverado (better halfs) '07 wildcat 27rlwb(for sale) http://67-72chevytrucks.com/vboard/c...llinois&cat=17 |
71 GMC 454/TH400
Re: 6 lug to 5 lug help please
The swap really is simple, the 71-72 axles will slip right in. On my 70 step side I used axles from a 72 van. The rears are the same width on all trucks 63-87, I also just put a 10 bolt with 2.73 gears from an 87 into a 72 GMC.
"The bigger you are the harder you fall, the farther you walk the longer you crawl." |
I have a set of good axles from my 72, I installed a posi unit and new axles and the stock ones were in great shape. I would be willing to sell them for $80.00 plus the freight. I am a board member and have paid my $25.00 to post ads. Please PM me if you are interested.
#4 | |
![]() Join Date: Jun 2002
Jim PA is right, the axles from a 71-72 are longer than the 67-70 (late 70 has the same length but since you have a 68 it doesn't matter)
People have used the longer axles in the older housings, but I think it is a bad idea, the wheel bearing will ride on the wrong area of the axle. I have always changed the whole rear end, it will bolt right in. Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Last edited by raggedjim; 01-30-2006 at 01:28 PM. |
