Old 01-31-2006, 10:41 AM   #1
bigjimzlll
bigjimzlll's Avatar
just did a 3" drop/disc brake on my 67
I used 71-72 drop spindles and rotors. I had the rotors drilled to a 5x4.75 pattern. I had to change both upper and lower ball joints to the 71-72 models. The trickiest part was making the 72 outer tie rod ends work. The 72 outer tie rod end is right hand thread(the 67 is left hand). The 72 is also a bigger diameter. What I did is to use the inner tie rod end off of the 67(add a 90 degree zirk fiiting) and the outter off the 72. I bought a 72 tie rod coupling and cut it in half. I cut the 67 coupler in half. The 67 will slide inside the 72 coupling and welded it together. Make sure and measure the length of the original tie rod first.
I am/was suspension ignorant.(stock) so if I can do it....
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 01-31-2006, 12:26 PM   #2
70c10
67-72 Addict!
70c10's Avatar
Re: just did a 3" drop/disc brake on my 67
Cool Jim, let us know how well it stops.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
