Old 02-01-2006, 01:06 AM   #1
lutherb69
Big Brakes On 68????
I was trying to find out what would I need to put big brakes or just disc brakes front and rear of a 68 Burban. Do I have to use stuff off the 71-72 or is there a kit I can get. If anyone has done the swap and have pics would love to see. Oh it is a C10 if that makes any diff.
lutherb69 is offline   Reply With Quote
Old 02-01-2006, 02:34 AM   #2
longhorn71
longhorn71's Avatar
Re: Big Brakes On 68????
you could swap the whole front cross member.It is easier or change the ball joint,tie rod ends and center steering link to the 71-72 stuff.the ball joints on the 67-70 trucks are smaller.You need to replace the master cylinder as well with a 71-up one.The disc brake frontend require more fluild then the drum fronts
If you swap to rear discs as well,you need a master cylinder for a four wheel disc brake set up(corrvette make good donors for this)
longhorn71 is offline   Reply With Quote
Old 02-01-2006, 08:19 AM   #3
You could put spindles and brakes from a C/30 on it.Everything on a 1t is bigger.If you want to put discs on it,the71/72s are the easiest.Do you plan to lower it?you could just get drop spindles or a complete conversion kit.
Old 02-01-2006, 07:20 PM   #4
lutherb69
Yes I want to drop it just don't know how low yet. Thank for the info, just want to make sure I have this right need to get set from a 71-72 for front and rear then get the kit.
Old 02-02-2006, 08:43 AM   #5
If you buy used 71/72 parts,you won`t be using the steering knucles/spindles if you are going with drop spindles.Which is the best first stage for a drop.If you want to be putting new brake parts:rotors/calipers/pads/hoses,and new bearings`n`seals,then the backing plates and a few little pieces are all you`ll use.The best way to go would be a disc brake conversion kit.I think the upper brake parts (master cyl/prop.valve) are included in the kit.
Old 02-02-2006, 02:19 PM   #6
lutherb69
thanks everyone 1 more question anyone know some good kits to get.
