Old 02-06-2006, 09:12 AM   #1
GMCPerson
Junior Member
Door Rod Clip Information Needed
I never could open the passenger door of my 67 from the inside. This weekend I took the door apart and found out that the rod that goes from the inner door handle to the latch was disconnected at the latch. The little clip that hold it in place has vaporized. Thinking that I was pretty smart, I got a clip from the extra driver's door that I had and tried to put it on the passenger side. After about 1/2 hour, I decided that the clips are different from right to left. The lock rod clip is also different.
I am sure I could get a new clip from one of the vendors but I would like to get my door back together tonight. Does any one know if NAPA or some other autoparts store sells these clips? I also thought about going to Home Depot to see if there is a retainer that I could just push on. Any suggestions would be appreciated. I may just drill a hole and insert a pin. This is not a show truck, I just need something that will work. Thanks, Paul
GMCPerson is offline   Reply With Quote
Old 02-06-2006, 09:34 AM   #2
QKENUF4U
QKENUF4U's Avatar
Re: Door Rod Clip Information Needed
had to do this last week on mine. NAPA has them, take one along so you can match it up. i had to go back twice since i didnt take one. 1$ or so a piece. they will have to give you the connectors for the carb linkage but its the same thing.
QKENUF4U is offline   Reply With Quote
Old 02-06-2006, 12:25 PM   #3
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
Autozone carries them too, but takes a lot of time to dig through the collection of keepers.
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
Old 02-06-2006, 01:41 PM   #4
GMCPerson
Junior Member
Thanks for the help. I will stop by tonight!
Old 02-07-2006, 05:12 PM   #5
GMCPerson
Junior Member
I bought the parts last night from NAPA! Now my passenger can let themselves out!
