Old 02-07-2006, 12:18 AM   #1
Rokcrln
Rokcrln's Avatar
New frame or just a back half...
Well after alot of mesuring and checking I have decided my frame if to far out of wack to keep it as is. It started about 6yrs ago when I cut the rear frame off and stepted it it up 2" to get the frame to lay flat. But thios also ment I needed to notch the frame and then that was not enough so I body dropprd it. Then after moving twice I have finally had some time to re-visit where I had left off and that was aligning the body. It turns out that by not doing the work in a jig I ended up twisting and tweaking the rear frame. So now I ether need to get a new frame or cut the rear off and just build a new one from scratch. What have other people done for back halfs? Or should I start looking for a new stock SWB frame and do it right this time with a frame table?
Kevin
Rokcrln is offline   Reply With Quote
Old 02-07-2006, 03:27 AM   #2
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
Re: New frame or just a back half...
First of all, love the truck! I'm doing something similar to my bedfloor.
If the rest of the frame is fine.. I say backhalf it !
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 02-07-2006, 08:01 AM   #3
Rokcrln
Rokcrln's Avatar
Do you have some pics to share of your ride? Are the 22" in yet?
Also does anyone have a factory frame scematic (sp?) that gives all the frame details and dementions?
Kevin
Old 02-07-2006, 08:21 AM   #4
I have seen a link posted to frame dimensions before.I`d back 1/2 it,too.Keeping an eye out for a frame`s not a bad idea either.Unfortunately,that`s one advantage the east has over CA.I can find junker shortbed all over the place,I just have to get western sheetmetal(disadvantage).I doubt alot of shortbeds make it to "junk" status out there unless they`re wrecked.They`ve alway been so popular.I had a`70 back1/2ed by a race car fabricator.It started out as a 3/4t big block.Ended up with a pro-street shortbed.
Old 02-07-2006, 08:23 AM   #5
FuelCellGuy
FUEL CELL GURU
FuelCellGuy's Avatar
Here you go.
http://www.chuckschevytruckpages.com/framespecs.html
FuelCellGuy is offline   Reply With Quote
Old 02-07-2006, 10:20 AM   #6
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
I have a LWB frame if you want it. I know you said SWB but if your cutting ???
Any way its free and I'm not that far from you. Come and get it
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 02-07-2006, 04:05 PM   #7
Bowtie67
Bowtie67's Avatar
Love the Tarantula Trans mount..
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
Old 02-07-2006, 07:24 PM   #8
Rokcrln
Rokcrln's Avatar
That just might work! I think I will build the back half still but my front half has had some tweaking done to it as well back in the day. This way I could start off new and keep it all inline from that point. I priced up material today to build a frame table for my shop, that should help out with alot of projects I take on.
Kevin
Old 02-07-2006, 07:34 PM   #9
Rokcrln
Rokcrln's Avatar
Originally Posted by FuelCellGuy
Thanks for the link but it apears that is for leaf spring frames and it does'nt cover body mounts but I am sure it will come in handy all the same!
Bowtie67 Love the Tarantula Trans mount..
That was built to mount my 700R4 and also give the exhaust a place to hide as the ground jumped up at it.
Kevin
Old 02-07-2006, 07:36 PM   #10
1969owner
1969owner's Avatar
well to start off, you need to sell me those rallys! j/k. love the truck
1969owner is offline   Reply With Quote
Old 02-07-2006, 08:33 PM   #11
Rokcrln
Rokcrln's Avatar
Once I decide on new rims (20/22's) they will be fore sale! The rears are 11x17 and the fronts are I think 9x17 and I do not remember the back spacing.
Old 02-07-2006, 08:39 PM   #12
smbrouss70
smbrouss70's Avatar
Kevin
If you get that LWB frame and back-half it, we (the board members) require a detailed build-up thread. It's in the rules... look it up!
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 02-07-2006, 08:50 PM   #13
fletch4x4
fletch4x4's Avatar
Like you really need someone else to tell you....but i would back half it.
Im kinda wishing I did
best of luck!
Bagged/Turbo 1970 GMC C-10
Crew Cab 1984 Chevy R-20
fletch4x4 is offline   Reply With Quote
Old 02-07-2006, 08:51 PM   #14
DTerry
'70 GMC C-25 LWB
DTerry's Avatar
I'm not sure it matters to you (I think so, or wouldn't post this), but those specs are for 73-87 trucks.
1970 GMC C-25 LWB (middle of frame up)
5-7 drop with 3in drop spindles, flip kit with blocks and still keeping the 3/4 ton. Shaved drip rails and marker lights, rear roll pan, cowl induction hood.
1987 Camaro z28
350, vortec 305 heads. 10:1 comp, t5 trans. Street terrrorizer.
1988 Monte Carlo (Super Stock ashpalt race car)
My Truck
DTerry is offline   Reply With Quote
Old 02-07-2006, 10:13 PM   #15
Rokcrln
Rokcrln's Avatar
Yes I will at least back half it and their will be a build thread at that time. Here is a link with alot of pics to another build I have going on in my spare time. This may clue people in to what my screen name means!
http://www.norcalbroncos.com/forum/showthread.php?t=197
Kevin
Old 02-07-2006, 10:40 PM   #16
DTerry
'70 GMC C-25 LWB
DTerry's Avatar
That's sweet. We race cars, so I hear what you are saying about spare time. Watched the rock crawler at the Carlisle All Truck Nationals last year - fun stuff.
1987 Camaro z28
My Truck
Old 02-08-2006, 05:37 AM   #17
camaro__thunder
I will try to put up some more pics... no real progress. I'm going backwards and taking the drivetrain out to shave/finish/Tub my firewall and cleanup my airlines etc.. It was kinda put together just to "try it" So now I'm going to go back over the truck. Love the rally's! I saw them somewhere in a 20" and my rims were suppose to be here Mon. but the wheel mfg. is being kinda slow.
My Project 69 SWB
Old 02-08-2006, 08:27 AM   #18
Rokcrln
Rokcrln's Avatar
I know what you mean about putting it together just to try things out. That sounds like my last 4-5yrs with this one project. Although moving it 3 times non running and in pieces de-motivates you a bit as well. But as soon as I finish a customers vehical that is in my shop it will be time for my 71 to get finished. Then some day past that my rock crawler!
Kevin
Old 02-08-2006, 10:28 AM   #19
1970 CST Short Wide
Senior Moment
Give me a holler if you want the frame. Other wise I have to cut it up and scrap it
Pittsburg Ca
94565
Old 02-08-2006, 08:36 PM   #20
Rokcrln
Rokcrln's Avatar
I will let you know in th enext week or so. Is their any damage to it that you know of? I really anm only worried about hte back of cab forward!
Kevin
Old 02-08-2006, 10:38 PM   #21
mkundo
You have mail.
Dan
mkundo is offline   Reply With Quote
