02-08-2006, 01:45 AM | #1 |
Got Horsepower?
differential yolks
can you change the yolk on a 12 bolt without removing the cover. mine is worn allowing the u-joint to move back and forth and im finally sick enough of the vibration after almost a year to do something about it
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit" SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers |
02-08-2006, 11:30 AM | #2 |
Re: differential yolks
Answer:no.You need to get into the rear.Your pinion bearing is probably shot.Next,expect a broken tooth on the ring gear.
02-08-2006, 01:17 PM | #3 |
It's a catastrophic success.
Unless Im missing something I thought all yokes unbolt off the pinion shaft.
http://67-72chevytrucks.com/vboard/s...d.php?t=187706 |
02-08-2006, 03:09 PM | #4 | |
RIP Mr Ron
Yes you can change the yoke without removing the cover,BUT that is probably not the problem. As Special-K said it is probably the pinon bearing going bad. That said, you can even change the bearing and race without removing the cover, but I wouldn't for these reasons. If you have had the problem for a year you may have metal grindings in the rearend. You can pull the plug and run a magnet in the grease or just drain the grease and look to see. The bearings have a preload setting that has to be correct or it won't live long. If you plan to keep the truck it will be cheaper in the long run to have a expert do it if you don't have the tools and experience to do it. Good luck on this whatever you decide to do. Ron (Mr Round Tuit). |
02-08-2006, 03:12 PM | #5 |
Yes. Remove nut-replace seal- add new yolk-tighted nut (add a little blue locite tight).
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
02-08-2006, 06:04 PM | #6 |
Check out GMTrucks.org
Like Ron said. You'll have to either redo the crush sleeve or make sure the preload is the same as before on the bearing. I have seen that done using a beam style inch-pound torque wrench, but try to find one of those.
Where in Idaho you at? |
02-08-2006, 10:41 PM | #7 |
Guess I needs to reiterate.Ok,yes the yoke can be unbolted/bolted (nut) from the front w/o going inside.BUT,I think you should get inside,at least to inspect.
02-08-2006, 11:06 PM | #8 |
Agree with Special-K if you can move the yolk up and down with shaft removed. Also turn the yolk (both wheels off ground) to check for rough bearings.
02-09-2006, 02:01 AM | #9 | |
Got Horsepower?
i had the axle apart this summer and checked and the bearings are fine. the yolk is worn where the u-joint is allowing the joint to slide back and forth. so it sounds like i can replace it without opening it up. i'll go by the driveline parts shop get another one and a new u-joint then i will hopefully be vibration free!!!
