Old 02-08-2006, 08:31 PM   #1
boatpuller
boatpuller's Avatar
help..apc steering wheel install
hey anybody hooked up a horn on an apc wheel?i got it off ebay with minimal instructions,the install kit keeps talking about one or two wire set up,my 79 just has a little plunger peg that activates the horn not a wire.the wheel looks great and was easy to figure out .but the horn baffles me.
boatpuller is offline   Reply With Quote
Old 02-08-2006, 08:45 PM   #2
us111
Re: help..apc steering wheel install
humm,no clue but are they maybe talking about the wire's that go to the actual horn ????
us111 is offline   Reply With Quote
Old 02-08-2006, 10:53 PM   #3
corn
Does your horn button have two prongs on it? Plastic? Got a pic? If it does have two, one wire goes to one of the 3 bolts (ground) & the other goes to the plunger.
corn is offline   Reply With Quote
Old 02-09-2006, 09:17 AM   #4
Jim85IROC
Jim85IROC's Avatar
I had a grant wheel hanging around from a previous vehicle, but I didn't have any of the Grant horn wire crap, so I took the horn "pin" out, jammed a wire into the spring, then reinstalled the pin, which wedged the wire between the pin and the wire. I hooked the other end of the wire to the terminal on the horn. It works great, and there's no danger of the wire dislodging because it's a tight fit with the pin reinstalled.
As far as I know, the APC wheels are the same as the Grants or very similar. Even if they're totally different, I'm sure you can wire the horn the same way.
1987 GMC Sierra Classic 3500
454
TH400
My Sounddomain Page
Jim85IROC is offline   Reply With Quote
Old 02-09-2006, 07:23 PM   #5
boatpuller
boatpuller's Avatar
i'm honkin again thanks to you guys........ hey if you don't know ask.
