Old 02-10-2006, 12:34 PM   #1
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Question 3/4 ton brake drum confusion!
I'm very confused. I ordered new rear brake drums from the Autozone.com website for my truck and they just arrived. Problem is, they don't look like the right ones to me. ?
I have a 1971 C20 with what I believe is an Eaton rear. (it has the large salad bowl center and the bolts are on the front side)
On the website, they have 2 possibilities, one with a Dana rear and one without. I clicked the one without and ordered them. (see pics below) The ones shown are 11 5/16" X 2 3/4"
I haven't had my drums off for a few years (truck is off the road) but when I did have them off last, I had to remove the center hub and pull the axle to get the drums off. The ones below look like that wouldn't need to be done.
Questions are;
1) Do I have an Eaton rear as I described above?
2) Are the drums in the pics correct? If not, what are they correct for?
Thanks in advance for any help...
Bob
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 02-10-2006, 06:28 PM   #2
stueber68
1968 C20 Vortec Beast
stueber68's Avatar
Re: 3/4 ton brake drum confusion!
They are correct! You have to remove the hub from the drum. If I remember correctly the wheel studs are what hold them in place.
Ugly or not it still kicks a**!
stueber68 is offline   Reply With Quote
Old 02-10-2006, 06:45 PM   #3
bobs409
bobs409's Avatar
Thanks alot! I'm glad to hear I can use them. I'll have to get in there and see how to seperate them.
Bob
Bob
Old 02-10-2006, 11:48 PM   #4
drink2mny
drink2mny's Avatar
Take out the axle. then use a special hub socket. either has 4 or six prongs that will go into the spindle nut. take spindle nut off the a washer, then another spindle nut. The whole heavey SOB should slide of the spindle now..
The just get a brass drift and a heavy hammer and pound out the lugs. You can reuse them if you don't mess them up.
Then reverse process and all should be A OK....
Support The Board
drink2mny is offline   Reply With Quote
Old 02-11-2006, 12:30 AM   #5
roger0080
Yeah the wheel studs "pound" out very easily -- but be sure to take it in and have a shop with a press and PRESS on the new assembly together.
Last fall I POUNDED my studs into the drum and hub and let me emphasis the pounding part. The last 1/4" of the studs to get down tight are a bugger. Just take it in for the whole disassembly/reassembly. I wouldn't do it myself again without a press.
72 Chev C-10 90% restored (former AZ truck) ...
71 Chev K-20 Cheyenne my vacation crusier...
72 Chev C-10 Now retired and striped after many faithful miles...
72 GMC 1500 Retired to the junk yard after bought new in '71...
roger0080 is offline   Reply With Quote
Old 02-11-2006, 08:33 AM   #6
bobs409
bobs409's Avatar
Thanks guys, all good advice. I appreciate it.
Bob
Old 03-10-2006, 07:30 AM   #7
bobs409
bobs409's Avatar
Just a follow up...
Everything went real smooth and just as you guys told me. It was also the perfect time to justify buying a new tool for the garage.... A 12 ton shop press. (those lugs didn't give it any trouble)
Bob
Old 03-10-2006, 01:01 PM   #8
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
mmmm, new tool smell....
Congrats! Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
