Old 02-11-2006, 12:56 AM   #101
Rollie396
someday it will be done!
Rollie396's Avatar
Re: Air Ride For Dummies
Originally Posted by wink_tim
Thats max lift. Ride height is just a couple inches higher than the aired out pics.
ahhh good news!I'm goin with a very similar setup but mines still just a frame with bags.I've been real curious about what the ride height would be.
What pressures you running?I'd sure like to see a pic at ride height as well whenever you can.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 09-18-2006, 11:55 PM   #102
frankyrealtor
Hi, cool setup...Do you have any pics of the rear bag install . i am trying to install the back bags and i dont have a cup or any thing. the air bag has two places for the bolts and on for the sir fitting. do i just drill the the three hols out and bount like that . any info helpfull or pics to. Thanks Frank
Email
Frankmentesana@verizon.net
frankyrealtor is offline   Reply With Quote
Old 09-19-2006, 02:34 PM   #103
wink_tim
wink_tim's Avatar
Email
You are correct sir. I drillied 2 3/8" holes for bolts and 1 aprox. 1" for the fitting on the under side of the frame, same location as factory spring. Check back in this post, I made a template to transfer the marks. Very simple.
67 SWB
wink_tim is offline   Reply With Quote
Old 09-19-2006, 02:39 PM   #104
wink_tim
wink_tim's Avatar
BTW, this has been covered before, but anyone using Suicide Doors lower cups should consider triming them down about 1". I took mine back out and cut them, now my front cross member is maybe 1" off the ground aired out.They are way too tall as shipped.
67 SWB
Old 09-19-2006, 03:06 PM   #105
jimmydean
jimmydean's Avatar
Do you have a shot of your truck aired out with the cups trimmed?
<edit> I ask because I will be installing mine this week!
Also, are you running drop spindles?
jimmydean is offline   Reply With Quote
Old 09-19-2006, 03:08 PM   #106
wink_tim
wink_tim's Avatar
No, but if you give about 10 minutes I will go outside and take one for you. Oh, and yes I am running drop spindles, 2.5".
67 SWB
Old 09-19-2006, 03:33 PM   #107
wink_tim
wink_tim's Avatar
How about these?
67 SWB
Old 09-19-2006, 03:37 PM   #108
jimmydean
jimmydean's Avatar
you are running blocks in the rear too, correct? What size?
By the way, your truck looks great!
I will be installing my kit over the next week or so. I am trying to do it without pulling the bed and I should be ok. I don't have a garage that my truck fits into and I would rather not have to put the bed somewhere while I get everything done.
Old 09-19-2006, 03:43 PM   #109
wink_tim
wink_tim's Avatar
Yes, they are 2" blocks. It would be possible to do with the bed on, not easy, but possible. Let me know if you have any questions, I can try to help.
67 SWB
Old 09-19-2006, 04:57 PM   #110
jimmydean
jimmydean's Avatar
Mine will be a little different then the others on here, but I think everyones is a little different. I will be taking pics of mine to share as well, just in case my system helps any.
As it is I am running two lines off the tank, one for each side. My valves will be mounted on the frame under right under the cab for easy access. That way I have a shorter distance for the wires as well.
Old 09-20-2006, 12:53 AM   #111
frankyrealtor
great truck
Old 09-23-2006, 07:04 AM   #112
gringoloco
A guy with a truck
gringoloco's Avatar
Wink-
Want to make sure I've got this right.
You are bagged in stock spring locations front and back, with a 2 1/2" c-notch correct?
How far off the ground are the bumpers and pinch welds when aired out?
Truck looks great btw.-Chris
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 09-23-2006, 01:41 PM   #113
jimmydean
jimmydean's Avatar
He also cut down the front cups (about an inch left).
I am leaving my cups as is for now and may run a small cup in the rear to start with. I can go lower if I want, but going higher would mean additional work to drive it. At this point I would be happy to be on the road again.
Old 09-23-2006, 02:10 PM   #114
pharcyde05
pharcyde05's Avatar
the truck looks great do you have any plans for wheels
pharcyde05 is offline   Reply With Quote
Old 07-14-2008, 09:17 AM   #115
Ford Assassin
Ford Assassin's Avatar
Should be a sticky.....
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 07-14-2008, 01:42 PM   #116
67chevemall
67chevemall's Avatar
It is time to take the bed off. Got all my stuff ready.
minus the comp. switches and tank. Get that latter.
Thanks for this tread
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 07-14-2008, 02:53 PM   #117
Putter
More Cowbell....
Putter's Avatar
Maybe I overlooked this tidbit of info....but how do the bags mount on the trailing arms?
It looks like the bags have a center hole for air, but outer holes for mounting. Trailing arms have a center hole for the bolts.
See my problem?
Is there a bracket, do you drill extra holes, or is there a specific air bag part number to get to the hole is in the correct place?
Thanks in advance,
Putter
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 07-14-2008, 02:57 PM   #118
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Usually most bottom mounts on the bags have one bolt hole, which works great with the trailing arm. It's the top one that has two mounting studs or bolt holes.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-14-2008, 03:03 PM   #119
Putter
More Cowbell....
Putter's Avatar
So would the rear bag require a plate of any sort where the bag meets the frame? I just don't want to dive in half-informed.
The front has been well covered by several posts and makes perfect sense, including cutting the cups down....but the back doesn't seem to get as much coverage in the threads.
Old 07-14-2008, 03:20 PM   #120
SCOTI
SCOTI's Avatar
Some will choose to install a 'hat' that has the required holes. This makes for a much easier install but adds to the overall bag height (so it limits the total drop).
Others will mount the bottom of the bag through the original hole in the trailing arm & drill the required holes in the frame. This is much more difficult but allows for more total drop (or more air psi required per bag height which can help w/the overall 'spring' rate).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-14-2008, 03:24 PM   #121
gringoloco
A guy with a truck
gringoloco's Avatar
You will need to run a spacer up top, or drill mounting holes and a larger air fitting hole in the frame. If you want to be low, drilling is the way to go.
The bottom of the bag just bolts to the trailing arm via the coil spring hole w/ a 4" long bolt.
-Chris
Old 07-14-2008, 03:30 PM   #122
Hart_Rod
Hart_Rod's Avatar
ARR 21800 LCA
http://www.ridetech.com/more/test-posting/
Hart_Rod is offline   Reply With Quote
Old 07-14-2008, 03:54 PM   #123
shifty
Questionable
shifty's Avatar
Someone sells a product that allows you to mount rear bags without drilling the top of the frame?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 07-14-2008, 05:57 PM   #124
SCOTI
SCOTI's Avatar
I don't know if they're a 'standard' p/n. Contact ART to see if they still offer them (they were part of the rear CPP air-ride kit).
I made mine but then didn't use them because they would not allow for the full drop that I wanted.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-14-2008, 06:12 PM   #125
jorgensensc
jorgensensc's Avatar
I'm a cheapskate, so I just drilled the holes in the frame. Time consuming and tedious. Make sure and double check before you drill, if you are off even a little you will have to drill larger holes than what you wanted. On a side not, Now my exhaust hits the brake junction block on top of the rear differential. Has anyone else ran into this problem? Did you just remount the j-block oon the bottom of the differential? What was your solution?
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
