Old 02-11-2006, 02:29 PM   #1
Johns70
Johns70's Avatar
Question new body mount ?
just got new body mounts for the blazer and put them in but the doors are still sicky in the door jambs on the back side,any of you have the same problem? i'm wondering if i should take all the factory shims out and loosen the door hinges and front fenders and realign them.you can definatley see some sag in the door opening, wider at the bootom and closer at the top,speeking of top iwonder if i should loosen the bolts that mount the top at the windshield frame? any help or suggestions are apprecited thanks john
69 chevy short wide box project
70 GMC jimmy project
Johns70 is offline   Reply With Quote
Old 02-12-2006, 08:41 AM   #2
vtblazer
vtblazer's Avatar
Re: new body mount ?
Keep the top intact, it will keep thing's in place.
There's different 'thickness' mounts for different location's, did you put them in the right place?
I'd lossen the mount bolts, align again and shim where needed.
Under the firewall and the front of the bed mounts will have the biggest impact on door alignment.
vtblazer is offline   Reply With Quote
Old 02-12-2006, 11:07 AM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 02-12-2006, 12:40 PM   #4
Johns70
Johns70's Avatar
yes put them in the right spots,i pulled some of the factory shims out from under the firewall,three on one side and two on the right.this coming days off maybe i'll put two on each side on the mounts under the seats and thighten every thing down, maybe that will pull it back into place.thanks john
Old 02-12-2006, 12:59 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Make sure that when you tighten down the body bolts you crank em down just past tight don't reef on em cause it will move the body around that way also..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 02-13-2006, 10:30 PM   #6
jcfoote60
Active Member
jcfoote60's Avatar
I have been planning on doing this myself, so do you put the factory shims back in the same number and place? I had thought that was the way to go, but sounds like that may be an error in thinking??
jcfoote60 is offline   Reply With Quote
