Old 02-13-2006, 09:29 AM   #1
shelby987
shelby987's Avatar
what can I swap?
Well, i came across an 89 3/4t 4x4 down the road in need of serious body repair......thought it might make a good donor vehicle. I was thinking I could pull the front axle to get myself some disc brakes, the hydraulic clutch would be VERY nice, possibly pull the bucket seats. It's a manual trans, but I like my column shifter, so I likely won't swap that out. Hoping that the rear has a locker in it that I can pull, will rims fit on a 70?
Anything else that I could scavange to make it worth the time and effort? I figured once I was done, I would part out the rest of the rig.
Haven't looked at it yet, but in 89, would that be a 4 or 5spd?
Thanks!
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 02-13-2006, 11:04 AM   #2
Rod
Re: what can I swap?
Hmm that 89 is it a solid front axle still....if yes, then yes it could be used on the older style trucks..if solid axle it would be a GM 10 bolt front. I believe it would still be a 4 speed in the 89.
Is this an 8 bolt rimmed 3/4 ton or a 6 bolt rimmed 3/4 ton, either should fit anyway to the bolt pattern being matched in you earlier years truck.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 02-13-2006, 12:02 PM   #3
FormerMember
Unless it's a crew cab, it's IFS front.
Should have a 14B rear. Should be a five speed, if it's a manual. Motor should be a TBI350.
FormerMember is offline   Reply With Quote
Old 02-13-2006, 10:01 PM   #4
If it is a crewcab(old body style) it will have a 4spd.The only regular cabs with solid front axles in`88 &`89 were old body style 1 tons.
