Old 02-17-2006, 08:39 PM   #1
JIMS1972STEPSIDE
Junior Member
JIMS1972STEPSIDE's Avatar
Power Steering Upgrade
Hi, I am upgrading from manual to power steering on my 1972 C-10 with a 307 motor, after doing a dry run on the install of the brackets and pump, I found I have a clearance problem with the alternator belt hitting the mounting bolt of the steering pump bracket, has anyone installed a p/s pump and did they have the same problem I have, and if so what did you do to correct the problem.Here's a couple of pics
http://i29.photobucket.com/albums/c2...gpumpfront.jpg
http://i29.photobucket.com/albums/c2...e/MVC-010F.jpg
JIMS1972STEPSIDE is offline   Reply With Quote
Old 02-17-2006, 11:01 PM   #2
Jayss109
Active Member
Jayss109's Avatar
Re: Power Steering Upgrade
try a longer belt to the PS pump and move it futher towards the drivers side?? been awhile since i messed with that
________
Chrysler phoenix engine history
Jayss109 is offline   Reply With Quote
Old 02-17-2006, 11:04 PM   #3
truckdude239
truckdude239's Avatar
the 67 i helped convert to power steering we just ran the alternator and power steering off one belt
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 02-17-2006, 11:06 PM   #4
JIMS1972STEPSIDE
Junior Member
I can move the pump, but the belt will still hit the bolt on the p/s pump bracket, thanks for the thought. And because of the stagger between the pump pulley and the alternator, I can't use one belt.
Old 02-18-2006, 12:00 AM   #5
truckdude239
oh we used washers and longer bolt to line eerything up lol may someone got the answer for ya
David fuller
2000 Tahoe 5.3l 378
Old 02-18-2006, 12:16 AM   #6
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
You are fighting the old problem when you are running non-stock parts. That is not 72 correct PS or pulleys, so you have to hack/modify to try and get it to work.
PICKMUP is offline   Reply With Quote
Old 02-18-2006, 12:27 AM   #7
davidh
davidh's Avatar
Yep, nuts, bolts, spacers. It's trial by error. I had a 4x4 I added headers to and the front header bolt used the pwr steering bracket. I used a piece of conduit to space it. Have a little patience. Try to find a local truck set up as yours for a model.
davidh is offline   Reply With Quote
Old 02-18-2006, 12:40 AM   #8
davidh
davidh's Avatar
Better yet, try to go to a junkyard and get everything off one veheicle so it matches up
Old 02-18-2006, 12:50 AM   #9
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
I got my brackets and pulley from alan groves and it works perfect for any short water pump, as stated above your using a metric pump and its going to be trial and error, this will be the 2cnd v8 that will get there brackets this weekend.....
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 02-18-2006, 03:04 AM   #10
Ol'blue72
You can also think about movin the alt. to the pass. side with later model brackets. worked for me, but the heads have to be drilled for front mounts.
Ol'blue72 is offline   Reply With Quote
Old 02-18-2006, 09:28 AM   #11
dennislbrooks
dennislbrooks's Avatar
If you want air cond later- leave the alternator on the driver side. You can probably also fabricate your way around this. I used a modified Speedway Motors bracket for my power steering pump -- and fortunately still got to modify it. 8-)
dennislbrooks is offline   Reply With Quote
