Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 09-23-2002, 08:24 PM   #1
78SilveradoSWB
78SilveradoSWB's Avatar
Post Looking For 3/1 Leaf Springs
Looking for some real nice leaf springs for a 78 SWB. Need the standard 3/1 leaf, not the heavy duty 7/1 type. Send your responses to gemba@excite.com. Thanks! :p
78SilveradoSWB is offline   Reply With Quote
Old 09-24-2002, 01:16 AM   #2
Fast68Chevy
Fast68Chevy's Avatar
what exactly are you doing ? downgrading from HD to LD or replacing broken LD springs or ? looking for leaves alone or complete packs or ?
R
Fast68Chevy is offline   Reply With Quote
Old 09-24-2002, 02:44 AM   #3
78SilveradoSWB
Going to use a flip kit/C-section to lower the rear 5" instead of using a 4" drop leaf spring and shackle set. I want to then use airlift or ride-rite air support springs for the occasional hauling. I have been told that I could not use these air support springs with the drop springs, but I could if I use a flip/C-section. I currently have HD springs, but would like to use the standard issue springs to soften the ride and as suggested by a local drop shop.
Old 09-24-2002, 09:37 PM   #4
Fast68Chevy
i think al you would really need to do to accomplish getting std capacity springs is to remove a couple of the leaves from both packs. dont see any other difference otherwise, hm
good luck
Old 09-29-2002, 03:18 AM   #5
BaggedC10
Under construction!
BaggedC10's Avatar
good luck
Light-duty leaf springs have a different spring rate.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 09-29-2002, 10:17 AM   #6
73GMC
Proud American
rear leaf suspension
I have the rear leaf suspension from a 79 c10. good condition, will send you email.
73GMC is offline   Reply With Quote
Old 09-29-2002, 03:55 PM   #7
78SilveradoSWB
Re: rear leaf suspension
You got mail!
Old 09-29-2002, 06:50 PM   #8
Fast68Chevy
only because of difference in number of leaves.
also there are two different lengths, 51" and 56",. 56" woud be softer ride than a pack of 51" with same quantity of leaves.
i would just save time and trouble and simply remove 4 leaves, personally..
each to his own though
good luck
Old 09-29-2002, 09:14 PM   #9
BaggedC10
Under construction!
BaggedC10's Avatar
good luck
You are correct, but they were offered in 52" and 56" lengths.
