02-21-2006, 01:56 PM | #1 |
Optima Battery Help
My optima was delivered from Summit yesterday and I cant figure out how to install it. It came with 2 different base plates and neither one seems to work. The thick one seems to be the closest but it wont get locked in in the back. The part # I ordered was 9022-091 its a 75/35 thats what the Optima website said would work. Anybody else have some experience with these?
02-21-2006, 02:05 PM | #2 |
Re: Optima Battery Help
I have no experience with Optima's myself but, (a shot in the dark), have you tried it without either baseplate?
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
02-21-2006, 02:30 PM | #3 |
www.73-87chevytrucks.com
Unless my eyes are decieving me, the one on the right is the top plate. Technically for a 67-87, you don't need any plates for it to fit correctly. The back should slip under the lip and the front should be clamped down with the bolt.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
02-21-2006, 03:01 PM | #4 |
looks to me the one on the left is for mounting the battery in a horizontal(laydown) position with the terminals pointing up
02-21-2006, 03:52 PM | #5 |
Both plates say to be used at bottom of battery. I have tried both plates and no plate and nothing works. When I use no plate it slides in the back good but it seems too short up front and the clamp cant go down far enough to get enough pressure to hold it in place. Never thought I'd have this much trouble installing a battery.
02-21-2006, 04:07 PM | #6 |
Blank
I'm running a 78 optima I think its a little bigger. It fit in the stock battery tray with out plates. I had to bend the holddown clamp to fit the round contour of the cells. Its snug and looks great. hope that was helpfull
1969 lwb 4/6 drop 17x8-18x10 torque thrust II's 327-420hp 2004R 3.73 posi. 1977 Corvette 350-375hp 4speed, silver show car. 2002 S10 xtreme, work truck 2004.5 VW jetta GLI 1.8T 6speed, weekend warrior. 2013 Audi A3 TDI, the wife's car |
02-21-2006, 04:39 PM | #7 |
Jamie Hyneman is my twin
The plate on the left is designed for stacking these batteries during shipment. It keeps the posts from possibly making contact with a metal surface. Wal Mart and other batteries come with a similar plastic "base"
As to mounting the battery, I don't know. Measure it against your previous battery? You could use battery mat as a shim and raise the battery up some. Good luck.
Justin SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD Color Wiring Diagrams Now in High Resolution V8 and Cab and Cab and Chassis |
02-21-2006, 11:10 PM | #8 |
Another idea!
Man, don't flame me for this, but are you sure you are installing the clamp the right way? (Again, I have zero experience with Optima's) Question about the Optima, Which is better, the Red top or Yellow top? Or what's the difference?
02-22-2006, 02:34 AM | #9 |
Its been so long since I took the old battery out that at first I wasn't sure how the clamp went so I looked it up in my assembly manual. I actually tried both ways anyway. Since I didn't get the "this is how its done" answer I was hoping for I'm just gonna do some cutting and grinding and make it fit. Thanks to everyone for the replies.
02-22-2006, 02:50 AM | #10 |
Gone Fishing
You won't need the plates just mount the battery without them and you will have no probs
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
02-22-2006, 03:02 AM | #11 |
Red is for automotive, yellow is for deep cycle.
65 SWB 454 350T |
02-22-2006, 07:32 AM | #12 |
I have the red top and it mounts just the way the old battery did.
02-22-2006, 02:03 PM | #13 |
The problem is there are a bunch of different types of red tops. I think I just got the wrong one.
