Old 02-22-2006, 06:12 PM   #1
boraxman
Keepin an eye out
boraxman's Avatar
q-jet to square bore manifold adapter plate
*sold*
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 02-22-2006, 11:14 PM   #2
71chevytruckguy
71chevytruckguy's Avatar
Re: q-jet to square bore manifold adapter plate
puts a Q-jet on a square bore intake, right? if so ill take it.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 02-23-2006, 12:38 AM   #3
boraxman
Keepin an eye out
boraxman's Avatar
Thats what ive been told. Sending PM.
ZIP 91351
Old 02-23-2006, 10:11 AM   #4
RainFade
RainFade's Avatar
Most of them you can also flip over and go the other way, square bore on q-jet manifold.
71 K20 350/350/205, dealer air, 4" lift, Flowtech,Edel 1406 on 2101, procomp HEI,4.10's, 33x12.50x16.5 BFG MT's on slots. 4 wheel disc brakes.
My lame K20 page
My lame Eaton disc brake page
RainFade is offline   Reply With Quote
Old 02-23-2006, 11:03 AM   #5
boraxman
Keepin an eye out
boraxman's Avatar
I think youre right. The holes are opposite on the other side.
ZIP 91351
Old 02-23-2006, 11:32 AM   #6
70c10
67-72 Addict!
70c10's Avatar
Rainfade is correct.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
