02-23-2006, 10:39 PM | #1 |
A day should have 30 hours.
Air Ride Acc...
What kind of tank / compressor combos are you guys running for your air ride set up ? and whats best if you dont wanna jump, or have a 5 min rise time...
I got a 10 gal tank and a viair 460 compressor and i find its kind slow... thankx for the response |
02-23-2006, 11:08 PM | #2 |
its just $$$$$
Re: Air Ride Acc...
you have too much tank and not enough compressor. you either need another compressor like the one you have or a smaller tank, like 3-5 gallon.
02-23-2006, 11:09 PM | #3 |
Re: Air Ride Acc...
i haven't put them in the trunk yet, but i have 2 5 gallon tanks and 2 460 viair compressors
02-23-2006, 11:12 PM | #4 |
Re: Air Ride Acc...
so what your saying is smaller tank or another compressor
02-24-2006, 12:08 AM | #5 |
Epoxy Primer Friendly
Re: Air Ride Acc...
yes.. your air compressor is killing itself trying to build up enough pressure with that big of a tank. Get a 3 or 5 gallon(ditch the 10). If you are a switch junkie get another viar 460 and run it also into the 10 gallon, to have enough play/fill ratio. Viar performance data
02-24-2006, 01:35 AM | #6 |
someday it will be done!
Re: Air Ride Acc...
I have roughly 8 gal. and I'm gonna run 2 viair380s.I'm new to this but I've been told by many that one compressor wasn't enough to preform well.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
02-24-2006, 10:37 AM | #7 |
Re: Air Ride Acc...
Where are you going to run your exhaust ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
02-24-2006, 03:09 PM | #8 |
Re: Air Ride Acc...
i'm guessing turndowns, but they'll definitely be some custom bending in there somewhere
02-24-2006, 08:06 PM | #9 |
Re: Air Ride Acc...
I'm probably gonna have to run outside the frame.I'm gonna build the exhaust myself so I'll have plenty of opportunity to experiment.
02-24-2006, 09:20 PM | #10 |
Re: Air Ride Acc...
not to get off the subject, but Rollie where did you get these tanks and what kind are they?
02-24-2006, 09:51 PM | #11 |
Re: Air Ride Acc...
lvscott,I built the tanks out of 6" pipe.
sorry to hijack canadian trucker,I'm curious to know what you set your pressure switch at and how long it took for the 460 to fill that big tank.
02-25-2006, 01:18 AM | #12 |
Re: Air Ride Acc...
The rule of thumb is 1 compressor to every 5 gallons of tank. If you go any more your just going to kill the compressor.
Later Jr
Please become a site supporting vendor to advertise a business in your signature. you can do so here |
02-25-2006, 01:53 AM | #13 |
Re: Air Ride Acc...
That's pretty much the industry standard and the same that I've always tried to go off of. If you're looking for a quick filling compressor, that compact and affordable, then I would go with the Viair 400C compressor. It's the quickest filling pump and also the most affordable. However if you're lloking for more then 150 psi, or plan to constantly be playing the with switches, then you'll want a different model.
Clint Petree KP Components Inc. www.kpcomponents.com |
02-25-2006, 02:12 AM | #14 |
needin' money
Re: Air Ride Acc...
get some nitrogen it will go quicker
SWB Stands for Short Wide Bed |
02-25-2006, 10:01 AM | #15 |
Re: Air Ride Acc...
Go with an AZ ! Heard nothing but good about them.
air zenith[IMG]http://www.*****************/images/products_gallery/23.jpg[/IMG] Last edited by camaro__thunder; 02-25-2006 at 10:02 AM. |
02-25-2006, 10:39 AM | #16 |
Seņor Member
Re: Air Ride Acc...
I've got 2 3 gallon tanks and 2 Thomas 315's. I've been using that setup for about 5 years. I don't do a lot of up and down over and over so the Thomas' are fine).
02-25-2006, 06:45 PM | #17 |
Hotwheels?
Re: Air Ride Acc...
I run an engine driven on 2 5 Gallons, I would never go electric.
I prolly have 300 bucks in the engine driven setup. I love it.
1978 Money Pit - CUSTOM DELUXE!!!! |
02-25-2006, 07:44 PM | #18 |
Re: Air Ride Acc...
my switch is set from 110 on and 145 off because i am running 100 psi in my bags
